Old 05-23-2019, 05:22 PM   #1
willforster24
willforster24 is an unknown quantity at this point
Help in CT
Working on finishing my rb25 swap in my s13 and it will idle for a little just with a misfire and then die I have replaced just about everything and can’t figure out what to do next
willforster24 is offline   Reply With Quote
Old 05-25-2019, 07:54 AM   #2
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
- Wrong MAFS? Verify part number
- Fuel lines backwards?
- Big vacuum leak? (use a boost gauge)
- Injectors stuck flooding engine? (check oil for fuel smell)
- Throttle not opening or idle control not working?
- Unplug coils 1 by 1 while running see if any 1 does NOT make it worse - could be bad
- Same thing with injectors - unplug while running 1 by 1, all should make it run worse
Just some basics
Good luck
blkvrtswp is offline   Reply With Quote
Old 05-28-2019, 03:02 PM   #3
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
pee on it.
you need to check things like fuel pressure, both KOER and KOEO, if you have an aftermarket FPR, make sure the diaphragm isn't leaking,
