![]() What is your FULL name? Kevin Hurst
What is your email? [email protected] What is your phone number 7607028277 What is your City? : Long Beach What is your State? : California What is your Zipcode? : 90813 ----------------------------------------------------- Price: Offers welcome (also open to trades for power boats) The time has come to part ways with my much loved Z ![]() Unfortunately, with family and work I just haven't kept up with the car game and now my eyes are set on a boat for the family...so it's time for the Z to find a loving home. The car has a lot of upgrades, but I haven't driven it in 4 years (life got busy)! It is currently registered as PNO (Planned Non-Operational) in CA with a clean title. I am looking to sell the whole car as-is, part out, or trade for a power boat. The car will not pass SMOG in CA, so if purchased as PNO you'd need to take care of that prior to registration. I am the 2nd owner. SpecialtyZ did my service & tuning.The prior owner went to Stillen & Alt Z for service. The car has a lot of platform upgrades that can take anyone a long way if you want to put in a little elbow grease to make it your own. On to the pics! Car as it sit's for last few years: Last service (6/19/13) at SZ seen on Oil Filter (clutch/flywheel install) ![]() Z1 Intercoolers: Mod List (I'm sure there are things I'm forgetting, but here is a pretty complete list): Engine: VG30DETT Stock 370cc injectors NGK PFR6B-11B Spark Plugs (gapped to 0.035″) AMS 4 pc. Pulley Set Z1 Side Mount Intercoolers Z1 Dual POP Intake Powertrix Engine Grounding Kit Z1 Motorsports High Capacity Oil Cooler Kit Z1 Motorsports Silicone Intake Hoses (black) CZP Coolant Overflow Catch Tank Nismo Radiator Cap Greddy Magdrain (magnetic drain plug) Performance Electronics: Custom Tune by SpecialtyZ HKS Twin Power Ignition Amplifier Blitz SBC i-Color Spec R Boost Controller 120amp Alternator Transmission: Z1 Premium Short Shifter Zspeed Solid Shift Mount Bracket AMS Steel Braided Clutch Line HD Clutch Fork Upgrade SZ (RPS) Max Street Clutch SZ (RPS) Aluminum FlyWheel Shaftmasters Aluminum 1 Piece Driveshaft CZP Chromoly Clutch Pivot Ball New OEM Automatic Transmission Mount Suspension: Powertrix Race Coilovers (8k/6k) STILLEN Anti-Sway Bars Powertrix Adjustable sway bar end links Powertrix FUCA’s Powertrix RUCA’s Powertrix Adjustable Tension Rods Powertrix Rear traction rods Powertrix Rear Strut Bar (powdercoated black) AMS HICAS Elimination Kit w/Z1 solenoid bypass fitting New OEM Inner Hicas Tie Rods Z1 Motorsports Rear Subframe Bushing Collars SPL V.4 Outer Tie Rod Ends Energy Suspension Steering Rack Bushings Energy Suspension Front LCA Bushings Energy Suspension [email protected] sway bar bushings 21mm & 28mm Exhaust: Megan Downpipes Megan Testpipes Resonated 3″ H-Pipe/Axle-back Brakes: 12.75″ cross drilled rotors Wilwood Forged Superlite calipers Wilwood brake pads Motul RBF600 Fluid STILLEN Cross Drilled Rotors (rear) STILLEN Metal-Matrix Brake Pads Z1 Motorsports Brake Master Cylinder Brace SpecialtyZ Custom steel braided brake lines Wheels/Tires: 5Zigen FN01R-C Time Attacks (17×10″ +35 all around) Nitto NT555RII Tires (275/40/17 all around) DP Motorsport Carrera Cup (F:17×8.5″, R:17×9.5″) Yokohama S.drive 255/40/17 \ Toyo Proxes4 275/40/17 Sound: Alpine 6.5″ Front Components Kenwood 6.5″ Rear 3 way speakers Dual Head Unit Interior: 1999 JSpec Shift Knob Z1 Motorsports Red Stitched Shift boot and Ebrake boot Corbeau CR1 Seats (Black Micro-suede) w/Corbeau Sliding Seat Rails Lighting: Kaixen 5000K HID Kit 1999 J-Spec Tail Lights Fluids: Motor oil – Royal Purple 20W-50 Transmission Oil – Royal Purple Synchromax Differential Oil – Richmond Gear Oil Miscellaneous: AIV Delete PRVR Delete EGR Delete Carbon Canister Delete PTU Relocate Tuned by SpecialtyZ on 4/20/10: 349rwhp, 371rwtq @ 14psi (91 octane) I also have a few extra parts (reasonable offers considered): Brand New ASH-SPEC built turbos - upgraded 2560R style wheels in Manual (.63 A/R) TUrbo housings. Turbos T25 62trim turbine with T3 62trim compressor. Coated turbine housing, 14psi WG actuator, compressor housing inlet expanded to a tapered 2.385" inlet for ASH 2.5" planar inlet piping (also available & never installed). 17x10 +35 5Zigen FN01R-C Wheels with BRAND NEW Nitto R-Comp NT555 RII tires (275/40/17 all around) Please message me with serious inquiries / offers. Thanks! ------------------------------------------------------ |
Lol Zilvians show no mercy... get an actual price listed or what they said will happen and you'll have to write all over again. Re-host those pics so we can actually see!
Tags |
300zx, 5zigen, turbo, wheels, z32 |
