![]() if theres bubbling in the resivor or overflow which ever you call it
does that mean the head gasket is blown and if theres a leak by the timing cover and waterpump area?? if so should i A-fix it B-get new Ka C-sr20 swap D-Rb swap E-Vg swap hmm decisions decisions |
![]() Join Date: Jul 2007
What kind of leak are you talking about? Air is leaking, water is leaking, oil is leaking? More specific would be better for the one that is answering.
About the swap, it depends on what you want, and what you want to use it for. |
It's a coolant leak
i think maybe all i need to do is get a new water pump for it and replace and then see what happens All i want to do with the car is have a weekend drifter/time attack and have it where it gets me to where i need to be |
![]() Join Date: Mar 2004
More likely than not your waterpump is kaput.
Thus the boiling resevoir and leak coming from the water pump. As to what you should do, that's really up to you. Depends on a lot of different factors. |
