05-17-2012, 07:52 PM | #1 |
ka24det idle problem "UPDATE"
i just finished my ka24det project, finally boosted it =) it starts right up and idles about 900rpms, but when ever i press the gas pedal it revs up and then the idle just shoot all the way down where it feels like it wants to die, i put a video so you guys could kind of get an idea whatit does. if anyone could help i would greatly appreciate it.
my set up is t28 BB sard 550cc injectors z32 maf isis FMIC kit walbro 255 fuel pump ngk 7 heat range plugs enthalpy base tune for set up above. also my wastegate, BOV and boost gauge vacuum all hooked up to FPR vacuum line. http://s69.photobucket.com/albums/i5...er_media_share Last edited by 4drsleeper; 06-01-2012 at 10:16 PM.. |
05-18-2012, 12:36 AM | #2 |
invest in a wideband. i kno it help me with alot of confusions, i read alot of mail order tunes like urs and jwt are tuned rich, u might be flooding when coming down from rpms. just a thought.
05-18-2012, 07:10 AM | #3 |
I have a wideband I just haven't had the chance to install i yet but I will soon as I get home.. I just wanted to see if I did anything wrong with the turbo install like my vacuum lines, and also I have a line not connect to vacuum under the throttle body that I think it goes to my egr or evap system
05-18-2012, 07:23 AM | #4 |
check and clean iacv...
and it maybe tune related... i got a ka20det w no tune at first it didnt idle right and would die after a rev too it was a loose clamp on iacv... hook up ur wieband and do u have an adj..fpr
シチサn w/ka20det:in progress シチサnw/sr20det:stolen |
05-18-2012, 09:14 AM | #5 |
I didn't really mess around with iacv thou, the only ones I really touched where the coolant lines under the throttle body and the fpr vacuum line. n no I don't have a abjustable FPR
05-20-2012, 03:25 PM | #6 |
so here another video with wideband and boost gauge installed, you guys could see mu
problem with the idle. http://s69.photobucket.com/albums/i5...er_media_share |
05-20-2012, 03:49 PM | #8 |
no its not, i took off the BOV and plugged the flange with my hand and had a friend rev the car and it was still doing the same problem.... all of my friends are saying my tune is not good
06-01-2012, 10:21 PM | #9 |
so i finally got my downpipe welded, wideband installed and also the afc neo installed n tuned, but im still having the decel problem. if i mess with the decel setting on the neo its fixes the problem, but on a cold start its still idles like shit unless i raise the decel to 0.08% until it gets normal then i would lower it back down to 0.06%. SO from all of this i have came to a conclusion that my problem is that my DECEL setting on the ecu are all out of wack....
