Old 09-21-2010, 02:51 PM   #1
AnotherZenkiKid
AnotherZenkiKid's Avatar
AnotherZenkiKid is an unknown quantity at this point
Send a message via AIM to AnotherZenkiKid
Kouki + interior lighting Questions
doing a kouki front end swap soon to my zenki
got some questions first though.
1.) What HID bulbs do i get?
i know zenki bulbs the part #s are 9005 HB3, do koukis have the same part #?
2.) When wiring up JDM turn signals what is one supposed to do to make them work since im converting from a zenki, are they still pulg in play?
I know koukis are plug and play but what about zenkis?
3.)What size are the zenki dash bulbs wanting to change mines to an LED blue color?
any bit of info helps guys many thanks!
AnotherZenkiKid is offline   Reply With Quote
Old 09-22-2010, 06:15 AM   #2
AnotherZenkiKid
anyone wanna help me out?
Old 12-22-2010, 02:37 PM   #3
NissanEnthus
NissanEnthus's Avatar
NissanEnthus is an unknown quantity at this point
Did you ever get a response on these?
1. Kouki low beams are H1 bulb which are way different than zenki.
2. You do not have to mess with the wiring at all, just unscrew bulb and plug into JDM signals. JDM or USDM had seperate turn signal housings with same bulb.
3. My kouki dash is identical to your zenki...I believe they were 158?? But do a search in the forums and you will get an answer.
NissanEnthus is offline   Reply With Quote
Old 12-23-2010, 09:51 AM   #4
xxoreolovexx
xxoreolovexx is an unknown quantity at this point
yeah bro its h1 for low beams, 9005 HB, 158 dash, and i wanna say 1156 turn signal
xxoreolovexx is offline   Reply With Quote
