06-01-2015, 02:54 PM | #1 |
Any way to change from 4-bolt to v-band?
So, I've bee having an ongoing issue with my downpipe bolts wiggling loose from the turbo manifold, I currently have a 4-bolt patterned housing bolted to a Megan Racing downpipe. My question is, is it possible to have that changed without buying a whole new turbo exhaust housing? Or does anyone have any suggestions to help the issue...
I've had all 4 bolts work themselves out and almost lost my entire exhaust one drive because of it... boiled brake fluid... not fun... |
06-01-2015, 03:27 PM | #2 |
cutting the 4 bolt and welding a v band
Check out my build thread! http://zilvia.net/f/builds-builds-on...rhd-build.html |
06-01-2015, 03:39 PM | #4 |
Trader Rating: (24)
Feedback Score: 24 reviews
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
?? And get a flex section in the downpipe if you don't have one already. |
06-01-2015, 03:41 PM | #5 | |
And that looks to be what I need, however it still bolts to the downpipe and turbo... I must be missing something... |
06-01-2015, 09:41 PM | #7 |
Stage 8 bolts & fastners...
My SR20VET |
06-01-2015, 09:51 PM | #8 |
use good hardware or tack the bolts when using that adapter.
06-02-2015, 10:07 AM | #9 |
06-02-2015, 01:07 PM | #12 |
Stage 8 is a fastner supplier, specializing in locking tabs and methods...
My SR20VET |
