Old 01-17-2010, 12:11 PM   #1
ichibans13.5
ichibans13.5's Avatar
ichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choices
Thumbs up FS Big Part Out - s13 and sr20 parts - some audio
I am located in Worcester MA- and most of this stuff was installed at a body ship that closed down half way through my body work and screwed me over - i towed the car home to find frame rail rust and started the part out.
all parts are for a s13 obviously some are universal with the s14 but do your research first. and all motor based parts such as radiator and hoses are for the sr20det. any questions PM me and i have pictures of everything. some things cant be shipped due to size. if you pm me for a shipping quote include your zip code. all prices are Or Best REASONABLE Offer - low balls will be ignored.
Sandblasted & Por 15'd Rear Subframe with Nismo Subframe bushings installed: $old
S15 Helical Diff installed in pumpkin by dsg with axles: $OLD
Megan Rear Camber arms 0 miles on just installed and adjusted: $old
Megan Rear Traction Rods 0 miles on just installed and adjusted: $old
Megan Rear Toe lower Rods 0 miles on just installed and adjusted $old
OEM camber bolts 2 Used $5 for the pair and 2 new $10 for the pair
Perfect running Finned Red Top sr20det (marroon top) known for being a late model with black top internals and oil pickup with tranny and with full wire harness conversion done, new iridium plugs, ignitor, maf, ecu, new coolant temp sensor, new toda flywheel, new copper mix clutch, icv cleaned out- had this isntalled and running but never put miles on it turbo is perfect condition- $old
Greddy Ti-C catback exhaust- installed and started motor with this on the car but never left the garage- cant find silencer tho- $old
Megan Test Pipe- Same as above 0 miles on it- $old
RSR ceramic coated downpipe has a couple light scratches on it from a steep incline from getting into the garage- $old
megan racing turbo outlet elbow to downpipe 0 miles motor just started with this on- $old
oem rear A arms with energy suspension bushings installed- one needs new balljoint-$old
mint center console with both ashtrays-$50
Brand New in box Koyo Radiator for sr20- $250
Brand New in box Flex-A-Lite FAL-220 Dual 12 inch Puller Auto Electric Fans 2500 CFM $old
Brand New Samco S13 Sr20 upper and lower silicone coolant hoses- $old - Black
APEXi 507-N004 Dual Funnel Power Intake Kit S13 SR20DET- Never Used, polished by hand - $85
Work Aluminium Red Lug Nuts Barely Used-$old
New Single Flex-A-Lite Fan- by itself- $60
Perfect condition fuel pump assembly with stock fuel pump- $old
near perfect condition center console with both ash trays $old
brand new pre molded black carpet $120
suspension technique s13 front and rear sway bars brand new- both F+R endlinks and Front Rear bushings and mounts- $200
Brand New in box Dif electric dual fan controller with built in relays- $120
s15 chaser vented Hood with oem s15 hood hinges- $100
s13.5 conversion fenders origin and chaser- origins were installed but not painted and chasers are brand new $75 for each pair
alpine swx-1243d type x 12" subwoofer- $200 brand new in box NOT refurbished
alpine pdx 1.1000 stackable mono digital amp 1000watts rms- $390 brand new in box NOT refurbished
alpine pdx 4.150 stackable 4 channel digital amp 600watts rms- $320 brand new in box NOT refurbished
Im sure i have even more stuff i need to go through.
Check my previous posts as i have posted pictures of pretty much everything!
ichibans13.5 is offline   Reply With Quote
Old 01-19-2010, 10:25 AM   #2
vqboodah
vqboodah's Avatar
vqboodah is on a distinguished road
do you still have the brackets for the front and rear sway bars?
vqboodah is offline   Reply With Quote
Old 01-19-2010, 10:36 AM   #3
lightsource
lightsource's Avatar
Trader Rating: (41)
lightsource is an unknown quantity at this point
Feedback Score: 41 reviews
Send a message via AIM to lightsource
Can I get pics of the lug nuts? Thanks
Do they have locks?
lightsource is offline   Reply With Quote
Old 01-19-2010, 11:47 AM   #4
ichibans13.5
Do they have locks?
yes they do
Old 01-19-2010, 05:28 PM   #5
ross.cottrill
ross.cottrill's Avatar
ross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant future
can you give me a shipping quote on the diff 32765..
" NEO VVL BABY FTMFW!"
Originally Posted by shagspeed
Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines
ross.cottrill is offline   Reply With Quote
Old 01-19-2010, 09:50 PM   #6
ichibans13.5
thanks for the inquiry - the diff actually sold about an hour ago and is on its way to canada tommorow!
Old 01-19-2010, 09:59 PM   #7
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
Is the black carpet OEM nissan? if not can you pm me brand/info on it.
PinkPanther is offline   Reply With Quote
Old 01-20-2010, 05:55 PM   #8
ichibans13.5
it is not oem but it is still new in the box so i will get the name off the box tommorow and PM you
Old 01-21-2010, 03:06 PM   #9
ichibans13.5
sorry i missed this post earlier
i do have both front and rear endlinks and the rear brackets and bushings the only thing missing are the front brackets and bushings that can be bought for around $15
Old 01-21-2010, 04:47 PM   #10
nochain
nochain is an unknown quantity at this point
will you do 75 shipped to 93004 for the traction rods?
nochain is offline   Reply With Quote
Old 01-22-2010, 04:16 PM   #11
ichibans13.5
i have a sale pending on all the megan arms, rear lca and the rear subframe- supposed to be picked up this weekend
Old 01-23-2010, 12:43 PM   #12
ichibans13.5
PMd you and just in case anyone else is wondering
the carpet is still brand new in box never even opened and its brand is Auto Custom Carpets Inc.
ACC: your authority for custom automotive carpet, floor mats, and more
cost me $270
some reviews on the company
BBB Review of Auto Custom Carpets in Anniston, AL
also they are the company that supplies autozone, jc whitney and pep boys for example
Old 01-23-2010, 10:23 PM   #13
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
you have some pretty dope stuff- glws man
I have 1000 hp. This thread is dumb.
Tom25666 is offline   Reply With Quote
Old 01-24-2010, 05:01 AM   #14
sincity_sil80
sincity_sil80's Avatar
sincity_sil80 is an unknown quantity at this point
interested in center console (either) shipped to 89131..please and thx
20 till 3:00 = ღ
sincity_sil80 is offline   Reply With Quote
Old 01-26-2010, 07:00 PM   #15
Kevin Y
Kevin Y is an unknown quantity at this point
pm is sent
Kevin Y is offline   Reply With Quote
Old 01-26-2010, 07:35 PM   #16
ichibans13.5
ok PM you that quote tommorow after i take some dimensions- the $50 one is the only one i have left it has the power mirror section - the $40 one did not have power mirror section but has already been sold
Old 01-27-2010, 07:54 AM   #17
90s13killa
90s13killa is an unknown quantity at this point
are the fenders fiberglass...how much for the hood and fenders shipped to 10312
90s13killa is offline   Reply With Quote
Old 01-27-2010, 09:49 AM   #18
JRwerks
JRwerks's Avatar
Trader Rating: (55)
JRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of light
Feedback Score: 55 reviews
Pics of black carpet?
JRwerks is offline   Reply With Quote
Old 01-27-2010, 09:07 PM   #19
ichibans13.5
its still brand new in box- do you want a picture of the box?
Old 01-29-2010, 12:36 AM   #20
Krewlkid
Krewlkid's Avatar
Trader Rating: (26)
Krewlkid is an unknown quantity at this point
Feedback Score: 26 reviews
Megan racing turbo elbow still available? if so are all studs intact? and would you do 60 shipped? PM me
Krewlkid is offline   Reply With Quote
Old 01-31-2010, 11:51 AM   #21
sthirteen02
sthirteen02's Avatar
sthirteen02 is an unknown quantity at this point
do you have sr ps pump by chance? if so how much 32837 shipped
sthirteen02 is offline   Reply With Quote
Old 01-31-2010, 06:07 PM   #22
ichibans13.5
megan elbow is still available i will check to make sure all the studs are intact but i also have a oem gasket for the turbo side also with that
as for sr power steering pump i do not have one sorry
Old 02-01-2010, 11:46 AM   #23
clv5045
clv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymore
is the fuel pump from a silvia or a 240sx?
91 240 cpe w/ sr SOLD
96 240 w/ sr
clv5045 is offline   Reply With Quote
Old 02-01-2010, 06:54 PM   #24
ichibans13.5
sorry just updated the list- sold a bunch of parts today to some locals
Old 02-04-2010, 09:09 AM   #25
living4surf
Trader Rating: (52)
living4surf is an unknown quantity at this point
Feedback Score: 52 reviews
$150 shipped for the sway bars to 33458
living4surf is offline   Reply With Quote
Old 02-04-2010, 05:25 PM   #26
ichibans13.5
nope and next time PM me an offer
Old 02-20-2010, 05:34 PM   #27
latin03001
latin03001 is an unknown quantity at this point
Thanks for the brand spanking new FALs!
latin03001 is offline   Reply With Quote
alpine, s13, s14, s15, sr20
