Old 11-06-2010, 09:01 PM   #1
initial240sx
initial240sx is an unknown quantity at this point
Send a message via AIM to initial240sx
SR20DET heating when i pass the 7psi
hi guys, need help...
SPECS:
-SR20DET Redtop
-Mishimoto Radiator
-OEM FAN, but is direct way..not controlled with fan sensor
-T25
-greddy profec type-s
i sent my 240sx to the mechanic, to install the boost controller, he tells me that, when he pass the 7psi to 9-10psi...in seconds the temperature reach 3/4... but if you keep the 7psi...the temperature stay normal...he check the radiator, thermostat, coolant and its OK. I ask him if the head gasket was ok and it does.
so what i can do?
initial240sx is offline   Reply With Quote
Old 11-06-2010, 11:35 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Running lean perhaps?
Old 11-07-2010, 05:53 PM   #3
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
I would check out your coolant temp sensor arrangement first make sure they are in good shape don't have a bunch of corrosion or crap on them and also make sure the grounds are good. Have the guy do a leak down or compression test if it;s free or you should run one just to be sure. Also do you have thermostat in? Make sure you have nismo thermo or at least a stock one.
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 11-08-2010, 08:07 AM   #4
initial240sx
yes i have the oem thermostat.. but i'm going to buy the nismo thermo, aftermarket headgasket and ARP headstuds... to see what happen...
Old 11-08-2010, 11:10 AM   #5
initial240sx
also, a friend told me, that i may have problems with the fuel pump, because in 7psi the engine work properly, but + boost = + fuel, so thats way the engine overheat... is this true?
Old 11-08-2010, 11:16 AM   #6
josephin510
josephin510's Avatar
josephin510 is an unknown quantity at this point
Running lean.
Trade my Rb25 for some wheels.
Buy my Sc300.
josephin510 is offline   Reply With Quote
Old 11-08-2010, 11:24 AM   #7
initial240sx
Originally Posted by josephin510 View Post
Running lean.
sorry, in past post i didn't understand the meaning of running lean, but i google it now... thanks
