Old 07-31-2009, 01:42 AM   #1
nikkirocksox
nikkirocksox is an unknown quantity at this point
Blacktop sr with no spark? Anyone??
I've got an s14 Blacktop. I swapped the ignitor chip into my boyfriend's car, fired right up. Checked the wiring to and from and they all have correct voltage on power and ground. So that's ruled out. Checked the cam angle sensor. same situation. There's power and ground running to each of the plugs. Also the correct volts, bla bla bla.... And still no spark. Last on the list is the ecu. It's not allowing us to get into the diagnostic mode, nor will it communicate with my buddy's modis scan tool. but i don't see how the ecu would just crap out?? Any ideas or advice on the matter would be much appreciated. Thanks guys
nikkirocksox is offline   Reply With Quote
Old 07-31-2009, 11:45 AM   #2
nikkirocksox
Please guys :/ haha. I need some help!
Old 07-31-2009, 05:24 PM   #3
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
My ECU just decided to crap out on me one day. Does your fuel pump prime up at all?
Old 08-05-2009, 12:56 PM   #4
nikkirocksox
yeah... definately getting fuel pressure...
Old 08-07-2009, 02:41 PM   #5
BlackTopS13
BlackTopS13 is an unknown quantity at this point
Its very easy for your ecu to just take a walk. If you have checked everything else you may have just blown a driver in the ecu which runs power for the spark. I drive a blacktop S13 but work for volkswagon and ecus go all the time its not all that uncommon. see if you can get one with the same part umber and try it.
BlackTopS13 is offline   Reply With Quote
Old 08-09-2009, 05:22 PM   #6
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
try changing the coilpack harness. those like to take shits on you too.
make sure its grounded on the back of the block aswell
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 08-12-2009, 08:54 PM   #7
Five_5Zigen_4
Five_5Zigen_4's Avatar
Five_5Zigen_4 is on a distinguished road
Hey crazies!! Its Jason, dude with the white s13 doing the swap...see you guys at the LTA every once in a while...you guys ever figure this thing out?? I'm honestly thinking ECU as well...might wanna see if you can find one on the cheap
73 240z Resto project
91 s13 hatch - SR swapped, blown up, parting out
Five_5Zigen_4 is offline   Reply With Quote
