Old 08-15-2018, 08:32 AM   #1
Rubber D
Rubber D's Avatar
Rubber D is a well-known jackass
Xterra bmc work?
Hello wall.. I usually don’t post because most things have been covered already. I was wondering if the mentioned brake master will work. It’s a 2 port so I would have to split the front brakes. Wanted to use a pathfinder bmc with three ports but my junkyard didn’t have one. My goal is to move the lines to the opposite side of the bmc, away from the down pipe. Any input is appreciated. Btw thanks to all members who post articals of info, helps a lot. Been lurking for almost a decade hah.
Rubber D is offline   Reply With Quote
Old 08-15-2018, 08:54 AM   #2
Agamemnon
Agamemnon's Avatar
Yes it will. I've seen it work before.
Old 08-15-2018, 09:21 AM   #3
Rubber D
Rubber D's Avatar
Thanks Ag. I might also try to run a b13 Sentra booster for a little more room.. don’t really mind having to push hard..
Old 08-15-2018, 10:02 AM   #4
tuzzio
tuzzio's Avatar
I bought a pathfinder master from ebay. works fine.
Old 08-15-2018, 10:21 PM   #5
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
You happen to have a part number for the one you bought?
Old 08-16-2018, 06:59 AM   #6
TheRealSy90
TheRealSy90's Avatar
Originally Posted by Rubber D View Post
Get a three port Pathfinder brake master cylinder, that also has the fittings on the opposite side. And they are available in different bore sizes.
Such a good signature.
Old 08-16-2018, 08:47 AM   #7
Rubber D
Rubber D's Avatar
It says tokico bm50 on it
Old 08-16-2018, 09:06 AM   #8
Rubber D
Rubber D's Avatar
