Old 03-30-2012, 11:06 AM   #1
mrcrazybutt
mrcrazybutt is an unknown quantity at this point
is there a difference?
So today some mechanic that works on 240s alot told me that a stock kouki sr20 makes more hp than a stock zenki sr20. I thought all s14 blacktops are the same. He said something about the harness and ecu. I was just wondering if this is true? I searched but couldn't really find an answer. :]
mrcrazybutt is offline   Reply With Quote
Old 03-30-2012, 11:53 AM   #2
ixfxi
ixfxi's Avatar
probably untrue.
think about it, if it is true... the difference would only be negligible
Old 03-30-2012, 01:07 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Same size turbo, injector, and tune...so how would they be different? S15s different, same engine but bigger turbo, injectors and tune. Thats like arguing that S13 blacktops are different from redtops.
CLICK HERE!!!
Old 03-30-2012, 01:16 PM   #4
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
kind of off topic but out of curiosity, is the ecu mapping of s15 sr's different from the other sr's because of the 6 speed tranny?
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline   Reply With Quote
Old 03-30-2012, 01:23 PM   #5
fliprayzin240sx
Not the tranny, wouldnt made a difference to the engine if you slap a 5 speed on it if you blew the tranny down the road. Hell, I was running an RB25 tranny on my S15 engine cuz I got sick and tired of blowing S-chassis transmissions. Car went thru 2 6-speeds, 3 S14s, CA18, Os giken gear set, before it went RB25. Kept the same 4.08 final gearing...
CLICK HERE!!!
Old 03-30-2012, 03:47 PM   #6
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
'95-'99 S14 Silvia, 200sx
Blacktop 8.5:1 162 kW (217 hp) @ 6000 rpm 203 lb·ft (275 N·m) @ 4800 rpm T-28 7psi 62 trim 53.8 mm (2.1 in), .64 A/R housing, BB if JDM BCI-1 in T-04B housing
This updated version is also known as the kouki (後期, literally "later period") S14, or by enthusiasts as the S14A. A similar car was sold as the second generation 240SX in the United States from 1995 to 1998. The final model year of S14 production in all markets was 2000, called the Touring Model, which had a better engine, pistons and a high throtle on lower gears.
They are same
BTW Dont you know how to "Search" ? Why do we have to spoon feed you grown ass man...
