11-17-2014, 03:39 PM | #1 |
New Brakes!
I want ceramic pads but my local stores (where i get discounts) don't carry ceramic pads for non ABS 240s. I looked up the differences between the ABS and non-ABS parts and found that the ABS rotors are a couple mm different in dimensions. The calipers, however, have the same part number. my question is -- are the ABS pads the same as the non abs pads, but a different material? If not, can I buy the ABS rotors and pads even though i don't have ABS? Im thinking the only thing different would be a couple mm on the rotor and a spot where the ABS would hook up. thanks in advance!
and unless you have an amazing deal, I don't really care to do a brake conversion |
11-18-2014, 12:13 AM | #2 |
One time i really needed to move my car and i used a rear abs s14 caliper with my non-abs pads and rotors on my hatch , it worked with no prob i just couldnt use the ebrake but i was only moving it to buy another s13 caliper.. Ohh and also i used the s14 abs rear rotors with my s13 rear brakes to redrill my new rotors from 4lug to 5lug with no problems hope this give some info
Tags |
240x, brake, brakes, ceramic, s13 |
