For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Join Date: Nov 2010
![]() Feedback Score: 15 reviews
Socal white bunny 1.0, s14 wiring harness's
First up is my white bunny clutch setup I recently bought! Its has the d21 flywheel with a luk pro gold towing clutch, guy held around 350hp. I never used it but it has some good meat still left on it. Comes with d21 flywheel, 6 pressure plate bolts, and meaty a$$ clutch disc 120$ or trade for a upgraded KA flywheel or a clean stock one plus 60$
s13 dohc automatic ecu, eliminates the rev limiter on the 5speed, part number is # A11-B47 G10. Asking Sold/Sale Pending to Arsenal240sx You can check the number if you have doubt that its not a dohc auto on this link: http://www.jimwolftechnology.com/wolfpdf/ECU-ID.PDF s13 clutch pedal assembly, needs the sensors, but a great start on gathering a 5speed swap parts, come with JDM carbon fiber pedal lol SOLD s14 powersteering pump with bracket, difference between s13 and s14 is the s13 has 2 bolts on the backside and the s14 doesnt. and the s14 pushs around 1300psi compared to s13 1100psi. Asking SOLD s14 engine wiring harness unknown year, clean, and has a couple broken clips, no cut wires though! Pictures go from ECU to the MAF, end to end... 50$ s14 trans harness, A little dirty but nothing out of the usual. Im not completly sure but I think it from a 5speed. It has 2 cut wires, which is to the 2nd to last sensor, easy fix. Other than that everything is awesome. Last picture shows where it was cut. 30$ 91-94 s13 intake, its in good condition, no broken tabs. Its comes with a g60 maf, throttle body coupler, intake pipe, air box,and snorkel/fresh air tubes. asking Sold/Sale Pending to Arsenal240sx I also have a s14 short block in my garage unknown condition if you need something lemme know before I start to rebuild it and sell it for more. Head has been hot tanked and pressure tested, has low vaccum, good for a rebuild or simply just lap the valves and new valve seals. Ill take trades, prices are kinda firm, lemme know what you got. for fastest reply text 951-345-3092 Last edited by sandy ms6; 12-05-2011 at 11:45 AM.. |
Tags |
clutch, engine, harness, intake, motor |
