Old 04-16-2014, 09:53 AM   #1
.db.
.db. is an unknown quantity at this point
Isis exhaust hangs too low?
I put my isis single gt last night on my s13 only to find that against all the reviews it did not fit well. The bottom of the exhaust sits roughly 3" lower than the frame rail. I have isis o2 housing downpipe and test pipe. The rear section of the catback fits great - my only problem is the center piece. Has anyone else come across this issue and/or found a solution? I'm waiting to hear back from both isis and enjuku to see how I should proceed - but it's looking like I'm going to have to modify it in order for it to be installed properly.
Sent from my SPH-L720T using Tapatalk
.db. is offline   Reply With Quote
Old 04-16-2014, 10:10 AM   #2
n8ge
n8ge's Avatar
n8ge is an unknown quantity at this point
I'm having the same problem, I really don't know why they designed it like that. That's the only real complaint I have with it. It looks like I'm just going to have to cut it and reweld it. Really wish it were easier!
n8ge is offline   Reply With Quote
Old 04-16-2014, 07:05 PM   #3
.db.
I ended up loosening everything, jacking the exhaust up as high as it would go. Tightened the bolts and used a clamp and some exhaust strapping to hold it up at the subframe. Works great. Raised it like 2 inches.
Old 04-16-2014, 07:17 PM   #4
e1_griego
e1_griego's Avatar
Trader Rating: (24)
e1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond repute
Feedback Score: 24 reviews
^This is the correct way to install exhaust.
e1_griego is offline   Reply With Quote
Old 04-16-2014, 08:40 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Bending the hangers and getting hanger bushings helps too.
CLICK HERE!!!
Old 04-16-2014, 08:53 PM   #6
TheRealSy90
TheRealSy90's Avatar
Chopping all the mounts and tucking the exhaust above the frame rails works the best.
Such a good signature.
Old 04-17-2014, 06:19 AM   #7
Davedave
Davedave is an unknown quantity at this point
can you post pics of the finished product? I wanna see the difference. lol
Davedave is offline   Reply With Quote
Old 04-21-2014, 03:42 PM   #8
.db.
Here ya go. A lot more clearance than initially. Unfortunately I didn't take a pic of it at its worst but you know how bad it can be. There was a big difference.
uploadfromtaptalk1398116442301.jpguploadfromtaptalk1398116456762.jpguploadfromtaptalk1398116474947.jpg
