S14/ KA24De Wiring Harness Removal
It would appear that not too many people have done or are in the process of swapping an automatic ka24 for a 5 speed rb20det. However, I am. . and this is my first car. But i'm managing pretty well so far. Almost everything is in order, except for the wiring. I have a complete harness for my rb, along with it's ecu. Everything is ready to be dropped in for what I'm assuming is the last time. But how do I remove the original KA24 wiring harness from the car. How do i do this??
Selling s13 RB motor mounts, trade for s14 RB mounts |
Hey, I'm have an s14 with the rb20det harness I'm removing, I figure it should be close? When I take it out I can let you know whats up if you still need help. It's an old thread so pm me if interested.
A search would of yielded you many results
![]() Follow this Guide: S13 KA24DE Engine Removal : 240SX Technical Forum Its pretty similar to removing the harness in your s14. Obviously disconnect all plugs in engine bay and pop grommet out. Unplug from ECU and disconnect dash connector plug ( It’ll be located behind the ECU in the back corner}, then disconnect the blue relay . Just take a look and you will see whats connected . Feed wires out of hole were grommet was. Done. Reverse to install said wire harness. Dash Connector ![]() |
