Old 05-17-2015, 02:30 PM   #1
gmoneyfosho
gmoneyfosho is an unknown quantity at this point
s14 front mount install
i am installing my front mount RIGHT NOW and need the templates for where to cut. so far all i have found was on the greddy site with some half ass lines showing where to cut. is there any better templates out there?
http://www.greddy.com/upload/file/12020473_i.pdf
gmoneyfosho is offline   Reply With Quote
Old 05-21-2015, 01:10 PM   #2
theultimatehero
theultimatehero's Avatar
theultimatehero is an unknown quantity at this point
Probably not going to get anything more thorough than that. Every job like this will be different and vary depending on your car, the IC kit etc. Start making cuts and fitting, cut-fit-cut-fit, repeat until it's what you want.
theultimatehero is offline   Reply With Quote
Old 05-23-2015, 08:15 PM   #3
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
That guide is only if you are using their KA turbo kit. Usually you would have to cut out the battery tray. I couldn't get mine perfect so I ended up just cutting out a square in the battery tray.
DennisC is offline   Reply With Quote
Old 05-28-2015, 10:32 PM   #4
gmoneyfosho
Well, we got everything installed. The cuts are not pretty but everything is connected and the car runs a million times better than with the stick side mount. Thanks guys.
