Old 04-26-2012, 05:57 PM   #1
jacobzking
jacobzking is an unknown quantity at this point
Throttle pulley doesn't return all the way, revs stay high (1500rpm)
*****SOLVED*****
On my SR, when I let off the gas the throttle doesn't return back to fully closed. I have an aftermarket throttle pulley on the car (needed it for the swap anyway). Any help?
when i installed the pulley, i just removed the old one and tossed on the new one. seemed simple (just the pulley and and bolt to hold it on). am i missing a spring or something?
PS: it is definitely an issue of the throttle not closing all the way. i can go push the throttle pulley and it shuts and idles around 850rpm. also, i've already adjusted the cable itself and checked the screw for the throttle stopper.
*****SOLVED*****
jacobzking is offline   Reply With Quote
Old 04-26-2012, 06:26 PM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Im pretty sure in the factory TB, there is a spring that should be connected the pulley, that winds up when the throttle is opened, make sure that sping is still there i guess.
This could be totally wrong, im going off memory from my SR. If this is a KA then i have no idea =)
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 04-26-2012, 09:51 PM   #3
jacobzking
problem is that the "j hook" on the TB spring was not wrapped around the inner lip on the TB pulley. for anyone installing a tb pulley, you have to:
remove old pulley by removing the 12mm nut.
once its out you have to pull/slide the spring assembly towards you, almost all the way to the edge of the bolt (if you don't move the spring towards you, you wont be able to slide the new pulley on AND slide the hook on to the pulley).
put the new pulley in front of the bolt, but don't slide it on yet.
first wind the pulley so that the "j hook" grabs the slot on the new pulley.
now, you can rotate the pulley so that you can slide it in to position, on to the bolt.
tighten bolt.
attach throttle cable.
done.
Old 04-27-2012, 02:41 AM   #4
Walperstyle
Walperstyle's Avatar
^award for followup!
KA-T ORG-Function over Flush
