Old 04-05-2013, 10:04 AM   #1
smokin-kp61
smokin-kp61's Avatar
smokin-kp61 is an unknown quantity at this point
4.3L vortec s13 vert
I have a chance to get a 4.3L vortex engine ecu and wire harness for free i would most likely bolt a t56 trans to it and keep it na has anyone done this swap does oilpan hit xmember and will the shifter be to far forward or am I gunna have to just go for it and figure it out
smokin-kp61 is offline   Reply With Quote
Old 04-05-2013, 02:36 PM   #2
The Dude
The Dude's Avatar
The Dude is an unknown quantity at this point
I think you'll just have to go for it. I'm not sure it would be ultimately more cost effective than doing an sr20 swap, though.
The Dude is offline   Reply With Quote
Old 04-05-2013, 06:13 PM   #3
smokin-kp61
your right but if i could get a trans cheap enough might be worth it i have a 4 speed i could mount to it just need bellhousing and clutch
Old 04-05-2013, 06:50 PM   #4
The Dude
The Dude's Avatar
You will probably still need a new/modified oil pan or crossmember (check with moroso to see if they have any front sump pans), motor/trans mounts, driveshaft, and headers.
I don't know all the specs on that motor but I'm betting it's an iron block (heavy). It would be hard for me to go that route even if I did get most of the stuff for free.
Old 04-06-2013, 12:34 PM   #5
vas13hatch
vas13hatch is an unknown quantity at this point
That motor is basically a 350 with two cylinders chopped off. There are a few performance parts for it out there but nothing like an LSx. I think you should sell it and put the money towards something more conventional, but it would definitely be different if you did that swap.
vas13hatch is offline   Reply With Quote
Old 04-06-2013, 03:51 PM   #6
Got Insulin?
Got Insulin?'s Avatar
Got Insulin? is an unknown quantity at this point
Should also be noted that (at least locally), the T56 is between $800-2000, so cheap it may not be...
Got Insulin? is offline   Reply With Quote
Old 04-06-2013, 05:40 PM   #7
smokin-kp61
I don't have to use t56 could use a t5 which is a lot cheaper and there is tons of performance parts including turbo kits
Old 04-07-2013, 03:24 AM   #8
Croustibat
Croustibat is an unknown quantity at this point
Man you wont pay more if you use punctuation, so respect your readers and use it.
Croustibat is offline   Reply With Quote
Old 04-11-2013, 03:20 AM   #9
Justin95
Justin95 is an unknown quantity at this point
4.3 maybe puts out 190hp def not worth the hassle in my opinion
Justin95 is offline   Reply With Quote
Old 04-11-2013, 03:59 PM   #10
smokin-kp61
I either have LU3 block which is 200hp 250lb-ft, or the
LG3 block 215hp 265lb-ft.
The only problem i see is its a rear sump engine which is a problem everything else i can fab and make work. So if i can figure that out id figure around $2k id have a very unique engine swap
Old 04-11-2013, 06:37 PM   #11
The Dude
The Dude's Avatar
The LS1 is a rear sump motor as well. You may be able to modify one of the front sump pans designed for the LS1, but you'll also have to modify the oil pickup tube.
Old 04-11-2013, 06:41 PM   #12
PoorMans180SX
PoorMans180SX's Avatar
For what it's costing you in time and fabrication material, I'm betting you could dang near have a VQ35, which makes more power, sounds FAR better, is probably lighter, and not to mention easier to swap.
Why are you trying this again? Oh yeah, to be "unique"
Old 04-12-2013, 01:13 PM   #13
Alamo_City_210
Alamo_City_210's Avatar
Alamo_City_210 is an unknown quantity at this point
He did not ask for opinions if he should do it or not but for insight if someone has done it before. I think, if you got the money and skills, why not. No need to impress anyone for any reason. If you do it, you'd be the helping hand for others who may want to do it.
Alamo_City_210 is offline   Reply With Quote
Old 04-12-2013, 01:29 PM   #14
PoorMans180SX
I'm trying to help save the guy from a headache and a poor performing engine, but hey, do as you wish, it's not like I'm going to go to his house and stop him.
This is a forum, you can expect people's opinions and take them with a grain of salt.
Old 04-12-2013, 01:38 PM   #15
smokin-kp61
Wow thank you, someone that doesnt hate cuz im not jumping on the ls bandwagon
Old 04-12-2013, 02:17 PM   #16
The Dude
The Dude's Avatar
No one here even mentioned that you should be doing an LS swap instead...?
