02-17-2009, 12:22 PM | #31 |
It is a 5 speed, has a Silvia Knob and Boot.
Also has a Silvia Trunk Lock! Last edited by SR20DETdatsun510; 02-17-2009 at 12:47 PM.. |
02-17-2009, 12:41 PM | #33 | |
As far as what will replace them, I am not neccessarily into the retro JDM look. SSR's are not my taste unless they are SSR Professor SP2 or the newer school MKII's. Plus, the old school wheels are too small for my calipers. The exaust really needs to breath but I also agree maybe I can hide it more under the rear. I'm open to more suggestions though. |
02-17-2009, 12:45 PM | #34 | |
I did get a good price for this car but still had to pay alot. But I will take this car to a whole nother level! I am going for "clean" right now and then if I am not broke, go for more HP. |
02-17-2009, 12:52 PM | #35 |
Looks like a Zenki Motor, from what i've read and seen if the S14 motor has fins on the front head it's a S14 Kouki Motor. I believe there was a thread about this, search it up. However, the S15 motor didn't have fins, so it could be either Zenki or S15 motor.
Steve.
S14 326 whp, 311 tq @ 15 psi HKS F-CON V-PRO |
02-17-2009, 03:45 PM | #36 | |
Here's a link to some progress pictures. CoupedUp.net - Efficiency Slave |
02-19-2009, 10:49 PM | #37 | |
Please elaborate... I like the colors and action but is it only because they are made in Japan? Or are they? |
02-19-2009, 11:34 PM | #38 | |
Defi link system will show peak values and recored gauge actions, Warning system,Stepping motors, Very accurate, easy to wire up, no splicing of wires necessary Read up on them I have some and I love them i will buy no other gauge.
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
02-20-2009, 10:27 AM | #39 | |
02-20-2009, 02:58 PM | #41 | |
What ones should I def get and which ones are just not needed for street use? What's a good gauge for Speedo and Tach that match? |
02-20-2009, 09:14 PM | #42 |
I recommend every setup that has an upgraded turbo and fuel managment have a Wideband and thes gauges no matter what, Oil Press., Boost and Coolant Temp.(if the stock one is faulty).
I bought the Defi Tach and Defi VSD for Speed. It's like the 240SX Heads Up Display, it appears on the windshield. I don't know of many good aftermarket speedos that are analog. I would only be able to recommend AutoMeter and I don't necessarily care for those. |
03-03-2009, 03:55 PM | #43 | |
Besides not having the Opening and Closing cerimonies, they seem like they are quality Gauges. I mean racers have been using them for many years. I would say that they are race proven many times over. I might just go with them because they have matching sets including Speedo. I like the Ultra Lite II's or the Pro Comp II's. Defi would do good by creating a product line that includes all matching gauges with speedo too. |
03-03-2009, 04:41 PM | #44 | |
I am sure that you will enjoy them and be okay using them. Defi gauges are a lot of hype but they're very nice quality gauges too. |
03-03-2009, 10:55 PM | #45 | |
Let y'all know what I decide to install and do pics when I am done. Give me a month....hahaha |
03-13-2009, 04:09 PM | #46 |
Progress.....
Well, purchased the gauges!
Went with Autometer Ultra-lite II's. Got a "3 3/8" Speedo" (to 160mph) and "Tack" (to 10k rpm) and 2 1/16" Full sweep "Oil Pressure", "Oil Temp", "Water Temp", "Voltage" and "Fuel Level." Next I need to find wire diagrams of both the 510 and the S14 SR20DET so I can figure out what I can keep and what I can tear out. (BTW, are there diags here?) I have a basic idea of how I want to mount everything. I will put the Speedo and Tach in their Reg. posotions and put the Oil Pressure right in my face inbetween where the Speedo and Tach are. (currently the fuel level gauge). The other 4 I will mount down on my center console with my Boost and Turbo Timer. Give me about a month to get everything squared away. Then Pics!! |
03-31-2009, 12:58 PM | #49 |
03-31-2009, 01:09 PM | #51 |
03-31-2009, 03:47 PM | #53 |
It will depend on your Speedometer...it will most likely be programmed to accept a certain amount of pulses per mile(ppm) and most likely the pulses per mile of the stock S14 SR transmission will NOT be an accepted one by the autometer tachometer. So, I looked into this in case my gauge wouldn't accept the speed signal(pulses per mile) and you'll have to get a Dakota Digital Speed Signal Converter I think the part number is SGL-5 or SLG-5 or something.
Now the tachometer will most likely be able to be setup for 4,6 and 8 cylinder engines and maybe more but basically you're going to have to somehow set or configure the tachometer to read 2 pulses per revolution I believe and then it will read accurately. I hope this helps. Good luck. |
03-31-2009, 09:58 PM | #54 | |
Any help is immensly appriciated! I also emailed Autometer to see if they can help. Thanks again!! |
04-09-2009, 11:24 PM | #55 | |
06-24-2009, 05:35 PM | #56 |
Update!!!!
Well, had my whip put in the shop for some upgrades!
Had a new rear end put in. R200 Diff with Nismo LSD, Wolf Creek Racing CV's, Willwood Calipers, QA1 Coilovers, drilled rotors, SS brake lines, Datsport Mustache bar, Perrin 25mm Adjustable rear sway bar, poly bushings through out and redline LSD diff oil. I also had the whole engine harness rebuilt and a data tap put in so I can see what codes the engine throws. Looked like a chimp did it before. (Edwin Bravo) Connected the alternator field circuit so my HIDS worked better, Front wheel bearings repacked and adjusted, rear tranny seal replaced, Reverse switch sealed, Pitman arm urethane bushings, replaced fuel regulator, New Walbro 255 fuel pump, New Radiator over flow tank, Had 7 Auto meter gauges installed, heim joint inner bushing installed into control arm cross member due to front control arms binding. Hood release installed, NOS tail light harness' (I am waiting to put the NOS euro rear lights on) and a few odds and ends. She is a F'n sexy bitch now! She still has allot of stuff she needs but mostly cosmetic. I will post pics soon..... Last edited by SR20DETdatsun510; 07-19-2009 at 11:39 AM.. |
07-19-2009, 11:33 AM | #57 |
Ok, Here are a few pics as I promised. (I'll also publish this in a show off thread....)
I have more of the rear end but they are on my phone. So untill I can down load them or take some pics on a lift with my Dig Cam, these will have to suffice. First off, this is what I took out: The previous owner did some weird stuff to this rear end. Most weird is welding the Maxima Calipers straight to the control arm instead of using an upgrade bracket. So this is what replaced it: Here is a pic of the Wolf Creek Racing CV kit: (I will insert a pic of the new rear end installed here when I get the pics) Other upgraded rear end components are an R200 w/NISMO LSD, Willwood brake kit, drilled rotors, all SS brake lines, QA1 Coilovers, Perrin 1" sway bar, Datsport Mustache bar, all poly-u bushings and optional 5 lug conversion. I also had a bunch of other work done too. Gauges Before: After: Full set of Autometer Ultralite II full sweep gauges At Night: Still working on the console to mount the 4 gauges down below. Here's some interior shots: Ok, here are some wheels I have on it right now. I got them for a great deal. Cheap. And they were all refinished too. The only thing I do not like about them is the intentional "fade" they tried to do but I will rock them till I have to have them refinished myself. (silver with Polished lips) They are WedsSport RS-5's 17x7 +35 with Falken Azenis RT-615 205/40-17. Also Ichiba 10mm spacers and Kics racing composite r26 Neo chro lug nuts (sweet) . I also had my engine harness totally rebuilt and a data port installed to see what codes it is throwing. (next upgrade is APEXi engine management) Had a radiator overflow intalled, Greddy Pullys, Braided fuel lines, Tomei cams and a several other front end things. Ok, here are some more pics of the engine It runs sooooo much better now and it will scream with engine management!!! The next thing to do is get EM and get over to the dyno and post some numbers. Maybe rack-n-pinion but the rest is all cosmetic. To Be Continued........ Last edited by SR20DETdatsun510; 07-30-2009 at 01:15 PM.. |
07-19-2009, 03:51 PM | #58 |
please tell me you keep this car in a garage with like bank vault doors
08-24-2009, 04:59 PM | #60 |
Extra parts
I have a R160 LSD Subi diff for sale if anyone here knows any 510 guys that want one. $500 firm.
It is in excelent condition. Pick up only. I am in Nor Cal Bay Area. I will post this in FS section..... |
