S14 No start Issue ignition switch FIX
Ok so I've had issues with my car not starting at times...
I had new battery, starter, and rebuilt alternator
Symptoms: I go to start the car and you will hear the solenoid click only once...I would have to repeatedly turn my key back and forth about 30 times to try and get it to start...
We all know the the ignition switch goes bad especially on the 1995 model like mine..
If anyone is having that issue I just want to let you know you can get a Nissan Alitma ignition switch from the junk yard free..It works great just has a longer harness.
I got mine off of a 1995 Altima
Hope this helps some people out having this issue and if you need a switch asap you can get it off a Altima
Hope this helps!!!
