Old 04-26-2016, 08:08 PM   #1
Yirosuma01
Yirosuma01 is an unknown quantity at this point
J30 tach in s13
Anyone ever get the j30 to work in a s13 rb25det I heard of people doing it. I got one and adjusted it and still it's not reading right.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Yirosuma01 is offline   Reply With Quote
Old 04-26-2016, 08:09 PM   #2
Yirosuma01
J30 tach is what I meant.
Old 05-15-2016, 02:30 PM   #3
steveff
steveff is an unknown quantity at this point
I just screwed it straight into the dual cam s13 cluster no modifications or calibrating and it's spot on. It just doesn't fit perfectly so I have gaps that light shines through. Trying to come up with a clean way to fix it but it should be a straight forward install otherwise.
steveff is offline   Reply With Quote
Old 05-15-2016, 07:42 PM   #4
Yirosuma01
What motor are you running
Old 05-15-2016, 08:49 PM   #5
steveff
Rb20det but should be the same install because they're both 6cyl. Pulled it from a random J30 in a junkyard for like $15. Couldn't tell you what year it was but it works perfect.
Sent from my SM-G925T using Tapatalk
Old 05-15-2016, 09:54 PM   #6
Yirosuma01
Mine doesn't and I've adjusted it both ways and the highest it reads is half
