Old 09-23-2008, 11:05 PM   #1
makulit054
makulit054's Avatar
makulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of light
sr wont start!!! Need help please!!!
I was planning on wiring up some kill switches today. since I couldn't use the fuel pump relay, i tried the signal start off the ecu pin 34. i wired a switch into that wire, all i got was a click in the open and closed position. so i removed the switch and wired it back that it was. tried starting it again, just a click and no start. so, I tried jump starting the car and it started right up. I tried a different wire for a kill switch. this time i chose ignition switch ecu pin 36. same thing happened. now it won't start unless we jump start the car.
my setup is:
s13 redtop in s14
greddy emanage
greddy profec e-01
Can anyone help me out.
makulit054 is offline   Reply With Quote
Old 09-23-2008, 11:11 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
dead battery?
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 09-23-2008, 11:48 PM   #3
makulit054
makulit054's Avatar
so , i let the car sit for about an hour. went to try to start the car and fired up. let it run for 10 mins, shut it off and tried to start it again. all i hear is a click and no start.
Old 09-23-2008, 11:51 PM   #4
SoguRacing
SoguRacing's Avatar
probably a bad battery.
Old 09-23-2008, 11:56 PM   #5
Mikey88
Mikey88's Avatar
Mikey88 is on a distinguished road
^^^ agreed...if your only gettin a click but no crank or anything then yah...do you hear your fuel pump turn on?
Mikey88 is offline   Reply With Quote
Old 09-23-2008, 11:58 PM   #6
SoguRacing
SoguRacing's Avatar
the car starts when he jumps it. so he has fuel and spark. his starter works so i would just get a good battery. not charge the one you have but get a brand new battery.
Old 09-24-2008, 12:07 AM   #7
makulit054
makulit054's Avatar
yeah, i hear a fuel pump turn on and accessories turn on but when i try to start it, I just get the click. i also went back out to try and start it and it started. I shut it off and tried starting it again and just get the click. what is the start signal pin 34 and ignition signal pin 36 for?
Old 09-24-2008, 08:42 AM   #8
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Yeah dead battery imo...leave it off long enough it regains enough power to start once, then gets drained again.
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
Old 09-24-2008, 09:32 AM   #9
makulit054
makulit054's Avatar
problemed solved. it was the clutch interlock switch...
