Old 07-04-2012, 02:11 AM   #1
89fastback
89fastback will become famous soon enough89fastback will become famous soon enough89fastback will become famous soon enough89fastback will become famous soon enough
not as much as a build as a recondition
bought this car from a friend who has had it for a few years
car was already set up ok
sr20det
isis coilovers
rear upper camber arms
180sx brakes
wheels
welded
and half cage
first order of buisness was to get a exhaust has been open downpipe for a few years
not a bad fit or sound for a ebay special exhaust
scored these for back rent my roomate owed me so i figured id try em out
installed
hated that the car was not a solid color
next for some handling
after installing the set up found out tie rods were too short to be safely used due to modified control arms so we made tie rod extentions
scored this rear windo visor off a trade in at work and chopped it up to fit
some pics of testing car
next on list to do
traction rods, toe rods
solid subframe bushings
2jz swap
supermade aero
redo cage
89fastback is offline   Reply With Quote
Old 10-11-2012, 10:24 PM   #2
89fastback
so finally some updates
got tired of the sr blowing turbos, and transmissions. so i ordered this
and this happened
which lead too this
