Old 10-07-2013, 06:59 PM   #1
jerryscherry
jerryscherry is an unknown quantity at this point
BOV , 2 ports question.
http://www.cxracing.com/product/cxra...T/images/2.jpg
so im temporarily using a CX racing greddy knockoff bov, recirculated.
what is the bottom port used for? I heard you connect it to a boost source or something, is it okay if I plug it?
I noticed air can be sucked or blown through that small port. I tested it by blowing air into the recirculation hose, and air came out through the bottom port, also when you suck air , air will be sucked through that bottom port.
since the recirculation is on the intake, I think unmetered air is being sucked through that small port. Ive been having some boost hesitation at a certain throttle around 3800 rpmish. but once you step harder on the throttle the problem goes away.
so I plugged my recirc and let the bov run vta, problem disappeared. So ima assume it has something to do with that port. if I plug it will it cause any problems? or just tap into one of the charge pipes and/or t off the wg source?
thanks and let me know
(note, I already boost tested my system at 10psi, bov is not leaking. stock sr20det t25 redtop 7psi)
jerryscherry is offline   Reply With Quote
Old 10-07-2013, 08:00 PM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Leave it unplugged, or hook to the wastegate line.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 10-07-2013, 08:08 PM   #3
jerryscherry
when its unplugged, it seems like air is being sucked through it, maybe cus its a knock off,
cool i guess ill tap another direct boost source
Old 10-07-2013, 11:21 PM   #4
TheRealSy90
TheRealSy90's Avatar
My Greddy RS has two ports like the knockoffs and the bottom one is unplugged.
Sent from my iPhone using Tapatalk - now Free
Such a good signature.
