For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
11-22-2020, 03:13 AM | #1 |
Trader Rating: (31)
Feedback Score: 31 reviews
Megasquirt/Axles/Injectors/FLCA/Coils/Aerocatch/BBK/Bee*r/SR trans.. just come look
Hey everyone, I'm condensing all my shit to a single thread. Any questions, ask away!
Two sets of 3x2 axles Neither sets have torn boots. One set is from my prev setup (went 350z axles) and the other came off a 180sx. 60$ each set OEM SR20 coils I bought them brand new back in 2015. I put about 10k miles on them before I lost my chassis. They've been sitting in a box since then. I'm going standalone with upgraded coils and don't have any need for them. 180$ Wiring specialties coil pack sub-harness same condition as coils 30$ S13 VSS Came from an SR trans 150$ Aero catch locking hood pins It will come with both keys, new hardware, and new pins. I went with the "carbon look" ones like the ricer I am. I literally just took the carbon latches from the new kit I bought and reused all my hardware. So the hardware bag is unopened and you have the stencil from the packaging. Nismo decals for extra coolness. 80$ Nismo shift pattern emblem (5 speed) I went cd009, so obviously that doesn't work anymore for me. 5$ Nismo shorty clutch line This was from when I had my SR trans 40$ Togue Factory S14 silver valve cover nuts/washers I wanted black hardware instead SOLD SOHC MAF Works perfectly, it's pinned for use on an SR 40$ DIF Z32 rear conversion lines Brand new 40$ Philips daylight 9 DRL kit These are quality drls that you will actually see in the daytime. I was going to use them, but I bought 78 works headlights. 70$ No name electric fans 14/12 inch 40$ 12 60$ 14 Tein hard outer tie rods (M14) Brand new 80$ Mishimoto baffled oil catch can Needed to use a different style of can for my car 100$ Battery cut off switch 10$ MS2PNP SR20 I never personally used it (just powered it up to communicate to it). I want to get a different standalone. Comes with IAT/bung, CAS disc, and optional 26 pin input harness (NIB). 600$ P2M 550cc injectors. I used these along with a rom ECU I had. I never had any issues with them, I think I put around 8k miles on them. They're still in my fuel rail. 200$ Everything below this was from one car. The SR lost is main bearings, and these are all being sold off it. Everything is in working order. N60 MAF 80$ E5 ECU. ROM tuned for N60/ 370cc injectors/ T28 180$ 370cc injectors One of the injectors has an epoxy repair on the top. The side of it cracked off being removed from the rail. They can be installed and function perfectly. 100$ SR Trans- You will need to swap all your sensors and shifter over. The front cover has been resealed. SOLD Nismo fuel rail adapter- Went top feed SOLD Authentic Bee R rev limiter- Went standalone and no longer need. SOLD Tomei type s FPR- nothing wrong with it, just want to utilize Radium hardware. Comes with fittings shown. SOLD Agency power clutch line- I made a custom hardline and don't need it. SOLD Gktech SR water neck adapter- Package opened and that's it. I ended up not needing it. SOLD Pineapple subframe tilt bushings- For the S13 guys, control your anti squat with these guys. I've heavily modified my subframe, and don't need them. SOLD Unique auto creations s13 wiper motor cover- I have shakitto shock tower braces and can't use it anymore. SOLD Deatschwerks 370cc injectors- Purchased new in 2015, and they have about 10k miles on them before I went to 550cc. SOLD CTSV first gen 4 piston (loaded) Z1 sprinkle slotted two piece Z33 track rotors Stop tech street performance pads ZERO MILES on all parts. The calipers are shaved for the ctsv brake swap.com brackets. I will not be selling my brackets as I had modified them (heavily) for my GK tech knuckles (they're gone). All you need for the fronts are brackets of your choosing (ctsvbrakeswap or G2 carbon), and 300zx conversion lines of you don't already have them. 450$ for rotors SOLD calipers Techno toy tuning fully adjustable S13 FLCA.- Planned on using these, but I'm a GK tech whore and went all out when they did their sale. They've never been driven on, and I put dmax dust boots on the heims. All the other arms in the picture are sold already. SOLD ER Spec magnaflow high flow cat It's been installed, but never had exhaust ran through it. I want to go with a different direction for a cat. SOLD S13 subframe braces, coated in truck bed liner SOLD RSR D1 bushing Kit SOLD Last edited by mr.nismo.; 06-21-2021 at 11:32 AM.. |
02-13-2021, 04:33 PM | #17 |
Was looking for a tomei fuel pressure
Might be interested Also maybe the CAT I?ll let you know Sent from my iPhone using Tapatalk
