Closed Thread
Old 06-20-2012, 05:01 PM   #1
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
Exclamation Need money to repay bail.. FML~An line Galore~VOLKs~Coilovers~FD spec Shell++++
Fuck the law, fuck the police
The innocent man is once again put behind bars.
Out on bail, i have to fork out $3.5k so i have to sell whatever i have to make up for the amount before i have to go back. I also need money for attorney so time is money!!
Ill try and list whatever i have but just give me a text/call if you need updated pics or info.
Please take a look all the way to the bottom, ill make sure i will have something you are looking for!
+ I WILL UPDATE this thread with new stuff every week so check back!!
Links to SPECIAL DEALS BELOW
Best to reach me @ (626)274-4414 Text/call
So lets start "selling off assets like im fking MJ"
Oil Breather Catch Can - $150 / $165 Shipped
An -10s bunges throughout.
x2 XRP Kevlar Braided -10 AN Lines - $40 / $47 shipped
42in Long - 30deg swivel to 120deg swivel (great for relocated front oil cooler) XRP Kevlar braid is good for 500+Deg F and can withstand 1500+PSI.
Circuit sport -10 An line from Oil filter relocate kit. $20 / $25 Shipped.
Fk i dont know how long they are, sorry..
Godspeed GT28 Turbo - $260
Brand New.
I know what your thinking, GSP turbo.. china turbo.. blah blah this they suck. Honest truth, the only bad that can come from these is if it leaks.. but they come with warranty so if it leaks.. you get a new one. Now blowing it? chances are unlikely if you take care of your turbo because like all turbos, you need a break in period.. the idiots you see on here blowing them are the ones that just got turbo car, slapped a turbo on and start red lining the fk out of it. ALL TURBOS NEED BREAK IN!!
Godspeed Front Mount Intercooler Kit for S13 - $250 Picked up
I was going to use this kit but i went V-mount, this kit is brand new never used.
- Core is 24"x12"x3". End to end is 30"
HKS Style INTAKE FILTERS!! 3in and 4in Available! - $20 / $27 Shipped
Turbo Blankets from Jegs.
Small blanket will fit most T2 to T3 housing turbos - $45 Shipped / $40 Picked up
( T25, T28, GT25, GT28, GT30, GT35, 18G, 20g, TD06, etc )
Large size will fit most T4 housing turbos - $55 Shipped / $50 Picked up
( GT40, GT42, GT55, T67, etc )
- Blankets will come with 2 anchor springs
- Fiberglass construction, good for 1800deg. Fahrenheit
This is the same one Jegs sells for $90!
Greddy Style Blow-Off Vavle - $40 / $46 Shipped
- Comes with barb hoses, flanges, and weld on adapter.
Volk RE30 w/ tires - $1400 / Shipping varies, please contact me.
THIS IS FOR ( 3 ) Volk WHEELS ONLY! BUTTTT I also have x2 Rota SVNs 18x9.5 +20 offset
Specs:
x1 - 19x10 +22 Offset Front ( 1 Wheel only, Driver side )
w/ Tires - 245/35 19 93W (Minor stretch)
x2 - 19x11 +25 Offset Rear ( One side is polished )
w/ Tire - 275/35 19 100W
__________________________________________________ __________
x2 Rota SVN - 18x9.5 +20 (Hyper Black chrome) - $500 / $580 Shipped
Special ordered rotas, they dont make these offsets and i waited 2 months on them. Like new, only mounted tires and studs to see fitment, didnt like the tires so i took them off. No pic yet put shoot a text.
Project Kics R40 lug nuts (Gun Metal/Gold) 12.x1.25 - $160 / $180
Shipped
Brand New
So This is my pride and joy.. Its a misfortune but im sort of glad i have this laying around to help me get through bad times. Im not 100% on selling it but objects can be replaced later on. I only wish this can be bought completely as i do not really want the setup to be parted out.
This is a FULL AN LINE CONVERSION. Its 90% complete, its only missing matching lines for the fuel rail, PS AN converted lines, and -3 brake for the bleed return. Used on motor start up.. never got tuned so this setup has about 3miles on it.
Off the top of my head.
Head:
  • S13.4 Hybrid Valve Cover w/ -10AN breather bunges.
  • Oil Breather Catch Can as listed above
  • x2 BMRS Nylon -10AN from Cover to Breather Tank
Water :
  • Outlet converted -16AN bung (Outlet has swirl pot welded on with -6AN breather on top)
  • Inlet converted -16AN bung (Inlet has -8AN welded for swirl pot return)
  • Under Manifold water line delete, Thermo housing converted to -8AN loop
  • x5-7 assorted length BMRS -16AN Lines, Nylon and steel braided
  • -16AN inline Radiator Cap (Not pictured)
  • MR2 3 row radiator, it is perfect for this set up (Not pictures, no -16AN on yet)
  • Swirl Catch Tank with -8AN return and x2 -6AN inlet on top. Radiator cap enclosure.
Oil :
  • Circuit sport oil relocate blocks
  • x3 BMRS -10AN steel braided lines for block to Filter to Cooler and back to Block.
MSC :
  • Chasebays -3AN in bay brake hardline conversion line
  • DPI -3AN Self bleeding brake fluid cooler w/ short -3AN lines attached
  • Aluminum power steering tank w/ -10an feed and -6AN return
  • BMRS -10an Steel braided line for feed, -6AN nylon for return
  • BMRS -6AN fuel filter
Asking $1800 for the setup I will not part.
Lastly is my shell, it is currently at a shop and was getting reinforced but lets see if i get a buyer. Its half way there into being a fully prepped car, i never got the funds to put in a proper cage but i hope next buyer does put one in. Buyer of the shell will get my list of people that can help you fabricate anything you need.
List:
  • Tube front end (tubing is in the same standard as FD cages)
  • V-Mount set up with MR2 radiator
  • enclosed with wheel tubs (will clean any wheels you throw at it)
  • rear removable bash bar
  • supermade body kit (tube front was designed to also fit almost any kit)
  • opened rear wheel arches
  • Good - uncracked HUD Dash/Aerodesigns Red bucket seat/Nardi Wheel/5 lug conv(not installed)/extra subframe/AC components/carpet/clean door panels/power windows
  • Bad - Fully gutted interior/sound deadening has not been stripped/shitty spray paint exterior/cracked windshield/stripped body harness/unfinished underdash harness(i will recommend a cheap wiring specialist)/non-op registration(its solely for track)
Asking $2000
Other Parts not listed:
Stance coilovers missing 1 rear. The front will fit S13 or S14. Brand new, Asking $650 / $700 shipped.
Local brand coilovers S13 and S14 - $499 / $560shipped.
Dope coilovers, they are made by local pros and they ride soft/firm plus slam to the frame.
S13 bolt on roll cage - GSP - $350 New / $510 shipped
Greddy informeter touch - $400
2nd shell spare part out. White S13 hatch, front collision, will part any little thing if you can pick at it. Just ask what i have in it first.
Dont like what you see? Then I will get you what you need.
I have dealer accounts with almost every big name out there and also some small name brand out there. Just ask, im i need for any sale to make that dime.
You need a AEM EMS? $twelve00 Brand new (vendors here ask $1299) shhhhhhh
PFC D-jetro? $ten fifty to eleven hundred (vendors- $1300) shhhhhhhhhh
Uras style Body kit? $300
Carbon fiber hood? $350
Coilovers that slam to your mofking frame? $450
Wide fenders, over fenders, wheels, brakes, that Mugen SR25det crate motor?... ill go deep hunting that part for you..
Tomei/hks/greddy/ssr/work/volk/stance/Ohlins to Megan/gsp/cxracing... anything, just dont ask me shit when you dont have money, your wasting your own time and giving yourself despair. Also i dont do importing, so i cant get you a front clip and such, sorry.
Check out the body kits i have for $299!
WHY PM for PRICE?! $299 BODY KITS ALL DAY!! +MORE
Thank you for looking
PeaceOnesxWai is offline
Old 06-21-2012, 12:45 AM   #2
peewees1280
peewees1280 is an unknown quantity at this point
Willing to do 450 on Godspeed coil overs 3239056494
peewees1280 is offline
Old 06-21-2012, 04:20 AM   #3
Nismobound
Nismobound's Avatar
Nismobound is an unknown quantity at this point
damnit, legit parts/setup. bump. fuck the law. fuck pigs. im out.
Nismobound is offline
Old 06-21-2012, 05:47 AM   #4
Tempo
Tempo's Avatar
Tempo is an unknown quantity at this point
bump for your freedom !
IG - allen.kerose
Tempo is offline
Old 06-21-2012, 02:35 PM   #5
PeaceOnesxWai
Trader Rating: (34)
thanks guys!
Old 06-24-2012, 01:07 PM   #6
chuki.s13.coupe.
chuki.s13.coupe.'s Avatar
chuki.s13.coupe. is an unknown quantity at this point
Free bump for being cool.
chuki.s13.coupe. is offline
Old 06-24-2012, 01:30 PM   #7
PeaceOnesxWai
Trader Rating: (34)
Buy my stuffff!! I need money
Old 06-24-2012, 02:36 PM   #8
CharleyWopp
CharleyWopp is an unknown quantity at this point
happen to have cabin carpet or hatch tail lights in good condition?
CharleyWopp is offline
Old 06-24-2012, 10:23 PM   #9
PeaceOnesxWai
Trader Rating: (34)
yess i doo
Old 06-26-2012, 03:11 PM   #10
PeaceOnesxWai
Trader Rating: (34)
bimpitybompityboop
Old 06-26-2012, 03:56 PM   #11
digiceldrifter
digiceldrifter is an unknown quantity at this point
free bump for u
digiceldrifter is offline
Old 06-26-2012, 06:29 PM   #12
PeaceOnesxWai
Trader Rating: (34)
Earl fuel lines sold
Old 06-27-2012, 12:07 AM   #13
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
bump for you fuck the law !!!!!!!
jdm213 is offline
Old 06-27-2012, 01:17 AM   #14
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
wangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfection
Feedback Score: 36 reviews
Send a message via AIM to wangan_cruiser
that sucks you got put behind bars. glws
wangan_cruiser is offline
Old 06-27-2012, 02:08 AM   #15
isaac5021
isaac5021's Avatar
isaac5021 is an unknown quantity at this point
30 bucks for a fake HKS filter?! damn.
isaac5021 is offline
Old 06-27-2012, 01:55 PM   #16
PeaceOnesxWai
Trader Rating: (34)
^Damn just looked on ebay.. the fkers just whore themselves.
Price lowered.
Old 06-27-2012, 11:02 PM   #17
My$800S14
My$800S14's Avatar
My$800S14 is an unknown quantity at this point
interested in the long 10an kevlar lines, PM me
MAddDsBRO
LEHDABIHLOO
My$800S14 is offline
Old 07-02-2012, 07:33 PM   #18
PeaceOnesxWai
Trader Rating: (34)
hipity hopity hoop
Old 07-08-2012, 01:22 PM   #19
PeaceOnesxWai
Trader Rating: (34)
sunday funday
Old 07-15-2012, 03:30 AM   #20
AK0A
AK0A is an unknown quantity at this point
dude, how much for gsp outer tie rods and tension as well for a 14
AK0A is offline
Old 07-15-2012, 04:55 AM   #21
s0fa king
s0fa king's Avatar
s0fa king is an unknown quantity at this point
How much for the project kics? 160 or 180?
s0fa king is offline
Old 07-18-2012, 03:21 PM   #22
PeaceOnesxWai
Trader Rating: (34)
elo ello hello lo l
Old 07-18-2012, 05:34 PM   #23
KPNITRL
KPNITRL's Avatar
KPNITRL is making a name for him/her selfKPNITRL is making a name for him/her selfKPNITRL is making a name for him/her self
Fuck the police bump.
Lets talk about these $450 frame slammin' coilovers. Pics?
KPNITRL is offline
Old 07-19-2012, 03:22 AM   #24
PureRush
PureRush is an unknown quantity at this point
I'm in for pics of the coil overs too
PureRush is offline
Old 07-19-2012, 07:39 AM   #25
d_nice
d_nice's Avatar
good stuff here man
d_nice is offline
Old 07-19-2012, 08:37 AM   #26
enkei2k
bimpitybompityboop
hipity hopity hoop
sunday funday
elo ello hello lo l
2 bump limit. you can start a new thread in 3 days.
Ask enkei2k
xquizitditz
enkei2k is offline
Closed Thread
