Old 05-27-2008, 09:50 PM   #1
driven_
driven_'s Avatar
driven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to behold
Engine Dead Wont Start.
sorry guys i'm quite in a hurry and decided not to search, (yes i know, what a effin' noob i am)
but yeah. i turn the key and no click, no cranking or anything. all the accesories in the car works.
but i just cant seem to start it.
any ideas
its a 95' 240sx SE
sorry for not searching. Lol.
driven_ is offline   Reply With Quote
Old 05-29-2008, 01:53 AM   #2
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
umm..... have you tried jump starting the car or checking alternator fuse? or checking the starter with 12 volts to see if it spins?
gijoe69 is offline   Reply With Quote
Old 05-29-2008, 09:54 AM   #3
driven_
driven_'s Avatar
ive already jumped it, the fuses seemed to be okay.
Old 06-02-2008, 03:43 PM   #4
driven_
driven_'s Avatar
bump.
could it be the starter?
Old 06-09-2008, 02:33 PM   #5
Xantcha
Xantcha is making a name for him/her selfXantcha is making a name for him/her self
if all the interior lights work then it's probably the starter, or a wire going to the starter. Try whacking it with a wrench(seriously) while someone is holding the key in the start position. The starter internals can get gunked up and frozen. Also make sure both the wires going to the starter are in fact connected, and they're not broken anywhere. Good luck!
Xantcha is offline   Reply With Quote
Old 06-09-2008, 02:40 PM   #6
jinesz32
jinesz32's Avatar
jinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to behold
Send a message via AIM to jinesz32
could be your battery doesnt have enough volts, happened to me before, i installed a new starter about a month ago and the car didnt start, everything worked inside the car lights, radio etc, but when i try to crank it, there was NOTHING, try using jumper cables or switch a battery out with your friends or something. > good luck.
jinesz32 is offline   Reply With Quote
Old 07-09-2008, 03:48 PM   #7
952jz240sxr
952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices
you can pull your battery out and have it tested. same with the starter.
952jz240sxr is offline   Reply With Quote
