Old 03-18-2010, 04:48 PM   #1
Frankyy
Frankyy's Avatar
Frankyy is an unknown quantity at this point
SR weird and unique problem w/my SR
so I did a turbo upgrade 3 weeks ago, I went full out basicly
heres my problem
over 5.5k RPM when under boost in excess of 5 psi it seems like theres a speed limiter but for a gear.. theres jsut no response to the gaz pedal and the boost completely dies within half a second, anything under is fine 15 psi @ 4.5k RPM no problem If I boost at 4 PSI, it will go to 6k RPM + on any gears( did not try 1 and 2 too risky)
rev limiter is set to 7.2k RPM
speed limiter set at 180km
so the problem is not with the ECU, all the settings have been checked over by a proffessional, he has never seen this problem occur tried a few things to solve it nothing helped. it started to happen before with stock ECU and stock injectors
my question is: is there some sort of over boost protector or an internal rev limiter, anything of that kind I don't know
Frankyy is offline   Reply With Quote
Old 03-18-2010, 09:45 PM   #2
buentellomma
buentellomma's Avatar
buentellomma is an unknown quantity at this point
i could be wrong but i would have the ecu tuned for your mods... this happens to me from time to time
buentellomma is offline   Reply With Quote
Old 03-18-2010, 10:51 PM   #3
Frankyy
Frankyy's Avatar
ya tune is fine everything ECU related is fine, it was my fault, my stupidity, i removed the wire inside the stock intake piping, because it got loose and was making a rattle noise , now the soft ruber intake got warm and the suction squeezed the intake shut letting no air in
thanks alot
Old 03-19-2010, 07:37 AM   #4
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
what gear..
97 240sx se
0wn3r is offline   Reply With Quote
Old 03-19-2010, 08:40 AM   #5
Frankyy
Frankyy's Avatar
Originally Posted by 0wn3r View Post
what gear..
gears from 2-5, gear 1 doesn't make enough boost for the intake pipe to be squeezed
problem fixed though..
Old 03-19-2010, 11:24 AM   #6
0wn3r
0wn3r's Avatar
what? this thread just went from bad to worse.
97 240sx se
Old 03-19-2010, 02:58 PM   #7
Frankyy
Frankyy's Avatar
do you fail at reading?? my 3rd post I said I found and fixed the problem...
you asked a question I answered even thought it is fixed...
