Old 03-28-2013, 05:26 PM   #1
Danger_Dorn
Danger_Dorn's Avatar
Danger_Dorn is an unknown quantity at this point
SR SR Cranks but wont start. Timing perfect.
Hey guys, So backstory...I swapped in my redtop into my s14 about 3 weeks ago and everything is stock. I also have a WS harness. It was running fantastic and then the heater hose popped off and I blew my head gasket. I ordered a cosworth metal headgasket with ARPs and torqued down to 90. Got everything back together including timing set right. (intake at 10, exhaust at 12, cas lined up and center, crank second from left). I go to start it and all it does is turn over. No sputter or anything. I can smell gas, and if I take the plugs out there is gas on them. I unplugged the injectors and cranked to dry out the cylinders. Waited a while and tried again with maf unplugged and all sorts of variations...nothin. So what else could it be? Ignitor maybe? Please help me out as this DD. I searched all damn day and found not much of real relevance to my specific situation. I have pics of my timing set up if you tell me its wrong. Thanks guys.
Danger_Dorn is offline   Reply With Quote
Old 03-28-2013, 05:30 PM   #2
xoxide
xoxide's Avatar
This might be a dumb question but is your motor grounded to your chassis? I had this same problem ( I relocated my battery and didnt run a ground from the engine to the chassis), and My car smelled strongly of gas.
You may have also flooded your motor.
Old 03-28-2013, 05:45 PM   #3
Danger_Dorn
SR
thanks for the reply. Yes, i have 4 total grounds. 1 from the Intake mani to the firewall, one from the coil packs to firewall, one from head right behind the exhaust mani to wheel well/chassis, and finally the fusebox one for the harness.
Old 03-28-2013, 08:56 PM   #4
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Did you make sure the chain didn't jump when you took off the head? Make sure that cylinder 1 is TDC and the cams are where they're supposed to be.
godsmack is offline   Reply With Quote
Old 03-29-2013, 08:24 AM   #5
Danger_Dorn
SR
So I know it might matter but then agian idk. The chain may have fallen off the crank when I was trying to put a new belt on so I pulled it tight to get it back on. I know it may have moved but that wouldnt make a difference as long as the cams are in the right spot right? So if I have the crank lined up, and all the slack is in between the INTAKE and CRANK right where the CHAIN TENSIONER is then the cams are lined up and cas punched right I should be good right?.
Old 03-29-2013, 10:11 AM   #6
Danger_Dorn
Well, I went out and re re re checked my timing. It's dead on. So I has to be electrical.
Old 03-29-2013, 10:32 AM   #7
e5s4y
e5s4y is an unknown quantity at this point
ground the plugs out and check for spark? do you have the right amount of links in between the cam marks (or whatever the marker point is supposed to be)?
BustedS13: anything you can hide on your person is free. junkyard law.
e5s4y is offline   Reply With Quote
Old 03-29-2013, 11:10 AM   #8
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Ur getting fuel and air it sounds like. Check tha spark...
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 03-29-2013, 11:14 AM   #9
Danger_Dorn
SR
Yep just did the coil and plugs on the valve cover test, I had spark on all 4. I know its getting fuel because it was before and I havent messed with anything, I can smell gas and I can see it in the cylinders. My maf was good before my head gasket change and it didnt move so thats fine. My ignitor works since Im getting spark. I has to be timing but everything is where its supposed to be
Old 03-29-2013, 11:24 AM   #10
Danger_Dorn
Tried to post pictures...Zilvia failed at doing so
Old 03-29-2013, 11:37 AM   #11
ultimateirving
Well do you have Conzult? turn the ignition on, set the crank manually to 0TDC, then hook up conzult and see if it reads 0 also. If its different then maybe the CAS if off a tooth. Only other thing that i can think of to trouble shoot
Z32 with lq4 swap
Old 03-29-2013, 12:05 PM   #12
Danger_Dorn
Angry
No i dont have a consult. I just tried moving my cas around all crazy ways to see if it catches...nothing. It ran perfect before. Im out of ideas
Old 03-29-2013, 12:16 PM   #13
Kriskouki
Kriskouki's Avatar
Trader Rating: (200)
Kriskouki is just really niceKriskouki is just really niceKriskouki is just really niceKriskouki is just really niceKriskouki is just really niceKriskouki is just really niceKriskouki is just really niceKriskouki is just really niceKriskouki is just really nice
Feedback Score: 200 reviews
I think you might have a flooding problem.....Check ECU's grounding........But, be sure that you connect all the connectors into the right position.....Another thing is to check the CAS because it tells the ECU what degree the timing you are at, which relates to the fuel trim.......According to what you told, the ignition seems okay.......As I said, be sure that you have plugged in all the connectors/sensors securely......Also, be sure you plug in MAF when starting the car......
Parts dismantler....
Kriskouki is offline   Reply With Quote
Old 03-29-2013, 12:26 PM   #14
ultimateirving
Yeah man, you probably skipped or overlooked something upon reassembly. Its easy to do especially since you had to pull the head off. Grounds or connectors need to be reevaluated
Z32 with lq4 swap
Old 03-29-2013, 12:46 PM   #15
Danger_Dorn
Just went out and looked over everything...still nothing. I really dont want to pay someone to do my timing...it would be bs and shameful lol. I am honestly out of ideas. Just cranks and cranks. I smell fuel and i know the plugs are sparking. FML
Old 03-29-2013, 12:57 PM   #16
jilo
jilo's Avatar
jilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of light
if you have fuel air and spark, theres a good chance its a mechanical timing issue. to make sure, do the one thing nobody mentioned. check the ignition timing with a timing light/gun. also does the engine sound like it has good or bad compression? you may be off a tooth or so..
"just throw in like 8 packs of BBs and do a burnout.
DIY shot peen, done and done."
jilo is offline   Reply With Quote
Old 03-29-2013, 01:02 PM   #17
Danger_Dorn
I cant check it with a light if it doest start....i dont have a compression tester but I just put in a cosworth 1.8mm gasket with arp's at 90ft lbs. i also got the head cleaned and decked but that doesnt explain anything
Old 03-29-2013, 01:12 PM   #18
army240
army240's Avatar
army240 is an unknown quantity at this point
It's not because you have spark with the spark plugs off that they do fire when bolted in the head.
I know it's may sound stupid, but with the pressure inside the cylinder as well as the air/fuel mixture it's more difficult for the spark to happen.
It did happen to me and I did change the 4 plugs and it fired right away. I'm not saying that this is your problem, but it's a cheap and easy thing to change.
Frank
Life is a beat to beat
army240 is offline   Reply With Quote
Old 03-29-2013, 01:28 PM   #19
ultimateirving
Hold the boat a minute,
Did you replace the spark plugs with new ones after the blown HG?
Z32 with lq4 swap
Old 03-29-2013, 02:14 PM   #20
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Friends SR used to do this. His car would flood and we'd pull out the fuel pump fuse and crank it till it started, then put the fuse back in. Try that yet?
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 03-29-2013, 03:08 PM   #21
Danger_Dorn
No i havent replaced them. Should I? I have unplugged the injectors, cranked it dry then plugged them back up. Same thing. Crank and car no worky
Old 03-29-2013, 03:45 PM   #22
Danger_Dorn
Just replaced the spark plugs with BKR6E's...nothing. This is starting to annoy me. Just flipped the CAS 180. Still nothing. WTF!
Old 03-29-2013, 04:29 PM   #23
StryfeS13
It's Always Broken.
StryfeS13's Avatar
If you pull out your spark plugs and crank the engine does it shoot out fuel like a whale? Lol. Sure way to know if it's flooded.
I still think your timing is off. Hopefully nothing is damaged if the timing was off.
Gotta love Zilvia.
Old 03-29-2013, 04:38 PM   #24
Danger_Dorn
I hope so too but I dont know what could be off timing wise. Everything is where it should be according to FSM. i took out my CAS and turned it by hand, all 4 injectors clicked
Old 03-29-2013, 04:41 PM   #25
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Post a video of it and show us how it sounds while cranking and we can immediately tell you just by sound if your mechanical timing is off.
Gotta love Zilvia.
Old 03-29-2013, 05:38 PM   #26
Danger_Dorn
SR
http://www.youtube.com/watch?v=djdrX...ature=youtu.be
Old 03-29-2013, 07:01 PM   #27
StryfeS13
It's Always Broken.
StryfeS13's Avatar
It doesn't sound like it even has that much compression in that video...
Hopefully you didn't get your timing wrong in the first place and bend a valve or put a hole in a piston lol
Gotta love Zilvia.
Old 03-29-2013, 07:13 PM   #28
Kriskouki
Kriskouki's Avatar
Most of the time that the car won't start, I would look at battery, fuel and spark.....But, it seems that you have done all.....
Now you may want to look into your mechanical work you have done......If the car start before the head gasket failure, it should be started now......I am sure no electrical components would failed by the time you have done your head gasket thing.......
Check your timing as if you are out of timing, it won't start anyways......
Lastly, do the compression test.....It will tell you many of things.....One important thing is will will tell how you that the valves are leaking or not, which will also lead to your camshaft/timing setup on your system......
Old 03-29-2013, 08:09 PM   #29
jilo
jilo's Avatar
your mechanical timing is off, check it again. then check with a timing light. you cant cheat the system.
Old 03-30-2013, 08:08 AM   #30
Danger_Dorn
SR
So I have checked it and checked it and checked it again. I have my intake at 10 my exhaust at 12 (A little past) and there are 11 links from the first dot to the second. The crank is at 2nd from let (13 btdc) and I lined up the CAs with the right dot so when I push it in it goes to the left dot and lines up. After centering and bolting it in, I crank and still nothing. GETTING FUEL AND SPARK! Should I try taking off my gears and everything again? THIS SUCKS! Its my DD and monday is rolling around fast. Thanks errrbody.
