For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Join Date: May 2007
SR20DET part out!!! cheap, OBO!!!
ok, heres my whole powertrain and electronics up for sale. Its time to part all this out and go V8. Mostly all parts are pretty new, just used for like 5 races tops. so here i go. Everything is OBO but please REASONABLE OFFERS ONLY.
pics will be up as soon as i start removing parts starting -S13 Black top sr20det long block only with brand new water pump and ARP head studs - $500 cylinder #2 only has 90psi but all other cylinders have good compression vvvvv specs below ( cylinder #1 - 130psi / cylinder #2 - 90psi / cylinder #3 130psi / cylinder #4 - 130psi ) also long block comes with arp head studs and ACL rod bearings and i did do new pistons rings also but for some reason oil ring on cylinder #2 went bad. -GT28 BB turbo -good condition, no blown seals, normal turbo shaft play, made 321hp 309tq on 14psi - $450 -R.Y.O tubular manifold - SOLD -R.Y.O turbo elbow - SOLD -Turbo SS lines - $60 -S13-S14 sr20det wire harness already wired - SOLD (includes ignitor and extended injector wires) -S13 sr20det ECU - $100 -S13 Sr20det Tranny. still good, no grinds - $150 -Blitz EBC boost controller - SOLD -Greddy turbo timer - SOLD -Greddy Oil catch can - SOLD -ISIS intake manifold - SOLD -EXEDY stage 2 clutch kit less than 1000miles(includes clutch, pressure plate and lightened flywheel) - $500 -Apexi SAFC2- SOLD -Ultra Mounts SOLID aluminum Motor mounts - $70 -Peak Perfomance solid tranny mount - $50 -BMPC intercooler with mid mount setup piping with BMPC blow off valve - $180(inludes couplers too) -ISIS oil cooler adapter with lines(all is needed is oil cooler) - $100 -3" Turbo down pipe - $40 -Apexi Boost gauge (reads in Bar) - $120 -S14-S15 BMPC aluminum Radiator - $130 -Sr20det fuel rail - SOLD -Blitz Oil temp gauge - $70 -SR20det alternator - $50 -SR20det Power steering pump -$75 -sr20det light weight pulleys(alt/ps/waterpump) - $75 - Sr20det Crank pulley - $50 -sr20det coil packs - $60 -Sr20det Starter - $75 -Sr20det 370cc injectors - $50 -Sr20det throttle body - $50 PENDING SALE -Ford Mustand Electric fan, blows insane, never overheaterd and already wired for SR - SOLD -Sr T25/T28/GT25/GT28 outlet pipe - $30 -Samco Sr20det bottom radiator hose with thermo housing - $25 -BMPC FPR (missing lens but still works) - SOLD i think this is all, but i will post if i have more, cant think of anything else right now. here are most of the pics, more to be added once motor comes out of the car. Bmpc radiator s14-s15 Ford Mustand Single Fan Samco Bottom sr20det radiator hose with thermo housing Greddy Catch can with SS lines BMPC intercooler with mid mount setup with couplers and BOV Sr20det fuel rail and injectors (sold seperately) S13 sr20det ECU Apexi SAFC2 great condition!!! Blitz SBCII boost controller, brand new this sell for $400, comes complete, the controller itself has a crack in the corner but still works perfectly fine! Apexi boost gauge reads in Bars... maddd JDM tyte and very rare and expensive part, get it cheap!!! T25/T28/GT25/GT28 turbo outlet pipe ISIS coil cooler adapter with SS lines, all is needed is oil cooler and fitting for block, can get from enjuku BMPC fuel pressure regulator Greddy turbo timer Blitz Oil temp gauge, carbon black series with ss line already included **RARE** ISIS intake manifold - throttle body not included more pics to come! call me @ 954-604-1677 or shoot me a PM if ur intrested in anything. thanks!!
Aero-K Garage * Night Monkeys est. 2004
the buyer is suppose to be sending payment already, i messeged him today, if he doesnt reply i have someone else ready to pay for the catch can, and if neither come through by monday, ill let u know.
#17 |
^^ just sent u a messge man. been very busy at work this week i havent been able to leave to ship it out. ill have it shipped on saturday.
and everything is updated, still parts available.
FreshColdBeer.com
![]() Join Date: Feb 2008
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
holy crap your in coral springs florida, no one is from there, i used to spend my winters there with my grand parents, and well you prolly already know marilyn manson is from there too.... and a ton of old people who can't drive for shit....
#24 |
![]() Join Date: Jul 2006
Trader Rating: (53)
WTB; S13 SR20DET Redtop Various Parts Needed
I am putting a SR back to totally stock for my upcoming video series - my donor motor is missing quite a bit. Water Neck It is the neck in front that hooks to the bottom radiator hose If you have the mounting bolts too that would be awsome! I also need the alternator belt tensioner setup - I have the bracket but not bolts/nuts/washers I need the (3) bolts that bolt the power steering bracket to the block - I have the one in front I need the (4) bolts & small plastic isolators that go under them to bolt down the fuel rail I need the (4) water pump pulley nuts I also need the fuel hardline that monts to the rear of the fuel rail - I also need that rubber line and clamps to attach it as well as the bolt that bolts it to the intake manifold torwards the front I need the (2) turbo inlet pipe nuts/washers as well as the (3) bolts/washers for the turbo outlet pipe T25 turbo. I also need (3) turbo banjo bolts and crush washers for them. I need the stock catch can "black box" and mounting bolts and hose. I need the A/C bracket with mounting bolts Pix/prices shipped to Concord,NC 280825 [email protected] __________________ |
#26 |
Trader Rating: (53)
I have a coil pack harness for $35 shipped
[email protected] < Send Paypal as a personal gift (fee free) |
