View Poll Results: How ready would you be to swap in a VQ if more information was public, and cheap kits
I would sell my (SR, RB, KA-T) to make it happen ASAP 49 32.03%
I would wait till the economy starts to rise again 17 11.11%
I would weigh the costs vs the risks of having an illegal motor 18 11.76%
I still would not care about swapping a VQ 40 26.14%
I plan on getting a VQ powered car anyways 29 18.95%
Voters: 153. You may not vote on this poll
Old 02-24-2009, 10:43 PM   #61
rb25crazy
rb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of lightrb25crazy is a glorious beacon of light
do it do it ! i wanna get a smog legal engine in my car that makes more power already =D. plus the sound of a 350z motor is quite nostalgic even in stock form =DDD
rb25crazy is offline   Reply With Quote
Old 02-24-2009, 10:51 PM   #62
irax
irax's Avatar
what does that even mean?
Old 02-25-2009, 01:43 AM   #63
GSXRJJordan
GSXRJJordan's Avatar
Originally Posted by rb25crazy View Post
isn't there a lot more to this swap? i remember that guy on 240sx.org was talking about the fuel is different. doesn't use pressure to measure it anymore so you had to change the tank or something like that.
Going from a carb'd car to a fuel injected car, you'd need a high-pressure fuel pump. All fuel injected cars have "high pressure" systems though, so no there's nothing you'd need to do fuel-wise (except a higher-flow pump) to prep the car for the swap.
Originally Posted by irax View Post
Nissan AntiTheft System but the part you need is called the NVIS which is a little dongle that goes around the ignition lock
Are you saying you've got a connector that will trick the car into thinking the 350z/Maxima/etc steering column crap is connected? Or are you saying that you would still need the VQ-car's column?
Originally Posted by Yellow4g63 View Post
Stock Speedo won't work with the VQ swap right cause there is no Speed sensor in the trans.
Any workaround for that? I don't use my speedo now, but that is an interesting point...
Old 02-25-2009, 08:06 AM   #64
irax
irax's Avatar
that column crap bolts on to the 240sx column. so you need the 2 things from the Max/Z/G/M column, NVIS and the ignition lock.
as far as speedo goes there are multiple work aroungs but the simplest is using an abs source and a dakota digital converter.
Old 02-25-2009, 09:33 AM   #65
Gorilla Unit 33
Gorilla Unit 33 is an unknown quantity at this point
an easy fix to that would me to run a s15 rear. Since they have ss in them an then just wire that up if that was the case.
Gorilla Unit 33 is offline   Reply With Quote
Old 02-25-2009, 12:47 PM   #66
irax
irax's Avatar
you will also need the s15 abs computer as well.. but yeah it is very simple compaired to what others think.
Old 02-25-2009, 01:25 PM   #67
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I was thinking about a VH swap but not having A/C blows. Future customer right here.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 03-09-2009, 01:22 AM   #68
vq35hrNismo
vq35hrNismo is an unknown quantity at this point
dude thats sick right. wouldn't that mean you can fit the 4.2vq in there? with such a light body damn. in my 240 im going rb though. the vq in the 240 sounds hell mean!!
vq35hrNismo is offline   Reply With Quote
Old 03-09-2009, 01:26 AM   #69
vq35hrNismo
you know..the more i thought about it..(not sure if discussed earlier). i dont think id go with a vq swap. sounding a little heavy.
Old 03-09-2009, 01:30 AM   #70
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
What really needs to be done to get this going in cali is someone needs to finish a CARB legal VQ swapped 240SX. Once that happens people will more than likely sell and forget any thoughts about doing an SR swap if they can have something better and legal.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-09-2009, 02:52 AM   #71
DrifterE
DrifterE's Avatar
DrifterE is an unknown quantity at this point
That is the damn truth! I'd sell mine in a hearbeat for the legal vq swap, the more I do to my SR the more I would like it to be legal. Then i've always had the VQ swap in the back of my mind. I'm on the lookout for it. And in line if its plug and play, the harness, everything else is cake to get. Maybe not the difficulty, maybe just time. I got a job to keep in this crazy world now.
DrifterE is offline   Reply With Quote
Old 03-09-2009, 03:11 AM   #72
GSXRJJordan
^^^ The biggest problem I can spot with the whole "smog legal"/passing the ref aspect is the emissions equipment - you have to have the entire emission system from the donor car - meaning when you buy a VQ motorset, you'd then have to junkyard-hunt EVERY piece of emissions equipment (and associated accessories) and install them "in the OEM configuration"... that means not only does each piece have to function as OEM, they have to be sitting in the same places/etc as OEM.
... This is MUCH more difficult than just swapping the motor in, and I imagine that's why you don't see anyone passing the BAR refs with it yet.
Old 03-09-2009, 05:06 AM   #73
gotspins13
gotspins13's Avatar
gotspins13 is an unknown quantity at this point
Send a message via Yahoo to gotspins13
any info on where to pick up an a vq? and the adapters for the wiring?
im looking to get a list going for prices and such,
gotspins13 is offline   Reply With Quote
Old 03-09-2009, 07:50 AM   #74
jzepol1985
jzepol1985 is an unknown quantity at this point
I don't think any vq's are left on zilvia look on craigslist or your local auto wreckers. It can range anywhere from 2g's and up for a 350z/g35 you can buy a altima/maxima for less but I don't Know if it's more work in the long ru
jzepol1985 is offline   Reply With Quote
Old 03-09-2009, 11:15 AM   #75
edsones14
edsones14's Avatar
edsones14 is an unknown quantity at this point
Would definately do it! Ive considered this swap ever since i saw it done in one of the tuner mags, cant remember which one. I have a g35 and i love the car. If u could put together a swap that is feasable and reliable im in. If u could make it somewhat as easy as an sr swap that would be money.
edsones14 is offline   Reply With Quote
Old 03-09-2009, 07:41 PM   #76
LugNut18
LugNut18 is an unknown quantity at this point
Now that I picked up another 240, I'm loving this right now. Even though there is already a kit, I would much rather by from a member, especially one who has done the research.
LugNut18 is offline   Reply With Quote
Old 03-10-2009, 07:02 PM   #77
DrifterE
DrifterE's Avatar
This would also mean swapping in stuff thats needed from the VQ emissions equipment and making it work together with the KA equipment?
Old 03-10-2009, 08:17 PM   #78
murda-c
murda-c's Avatar
No you'd get rid of the KA equipment other than the gas cap.
maybe you could get away with keeping your evap or something like that if they work the same.
Old 03-10-2009, 11:37 PM   #79
irax
irax's Avatar
here is a rwd motor set. 1900! fucking awesome deal!
http://zilvia.net/f/sale-items/23370...d-harness.html
you can get a fwd motor set for 500-900 and spend maybe another 600 to make it rwd compatible and still spend less money by getting my motor mounts
Old 03-11-2009, 10:06 AM   #80
poziden
poziden is an unknown quantity at this point
im in... msg length
poziden is offline   Reply With Quote
Old 03-11-2009, 10:52 AM   #81
DreamN
DreamN's Avatar
Trader Rating: (54)
All I would need to have is proof that it was CARB legal and a write up of some sort that I can do it. No need for plug and play.
^ yeah, it's a total bitch, but the good thing is that there are a select few trying to get this done. Can't wait till one of them does so I can finally dive in on this VQ thing.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-17-2009, 02:24 PM   #82
PoorMans180SX
PoorMans180SX's Avatar
Dude, they're hardly heavier than KA's. And they can be placed farther back in the chassis. Way better weight distribution than an RB.
irax,
I will be buying a RWD motor set soon.
If your mounts are out I will buy them asap.
And to everyone else. If you're not worrying about carb stuff, then Haltech makes a full plug-n-play system with harness for $2300.
That's most likely what I'll be getting (Unless I decide to run MoTec for some reason) and then I'm installing an AIMsports Dash.
That way I don't have to worry about sensor compatibility so much.
Old 03-17-2009, 02:43 PM   #83
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
irax,
or you can use the stock ecm, im working on Irax's wiring at the moment, i plan to make his swap fully functional.
Review Thread
bardabe is offline   Reply With Quote
Old 03-19-2009, 04:30 AM   #84
irax
irax's Avatar
irax,
you could spend $2300 on a stand a lone, and it probably would be a great investment. But unless your spending 10k+ on your engine build you probably are not going to need it. You can tune the stock ecu, and get some neat stuff for less than $2300.
Old 03-19-2009, 07:50 PM   #85
gregfarz78
gregfarz78 is on a distinguished road
Interested in seeing if this project takes off, I changed my mind about swapping a VQ for other reasons but I'd still love to see this become a more common/easier swap.
anyone in PA looking for a VQ get in touch with me I got one for sale
gregfarz78 is offline   Reply With Quote
Old 03-20-2009, 02:22 PM   #86
PoorMans180SX
Well if you make an all-inclusive kit, then I'll buy it.
Old 03-20-2009, 03:18 PM   #87
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
I would love to do a good affordable VQ swap. Good power and reliability in one.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 03-20-2009, 03:26 PM   #88
johngriff
johngriff's Avatar
johngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfection
Send a message via AIM to johngriff
If you have the capital and design for the mounts now. Get a production run done in china, cheap metal + economic collapse = least expensive possible manufacturing costs.
Then just wait until next year and start selling the swap equipment.
[email protected]
johngriff is offline   Reply With Quote
Old 03-22-2009, 03:43 AM   #89
irax
irax's Avatar
yeah, problem with that is I support local.
Old 03-22-2009, 10:48 PM   #90
irax
irax's Avatar
what ecu do you want to use? if you want to use a maxima ecu because their cheaper ill sell you my personal engine harness when you buy a kit.
