Old 09-19-2008, 06:42 PM   #151
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
Yes Im going to run dual exhaust but out to the stock location pics below.
For the ps the hose you see is regular teflon braided hose, summit racing sells this stuff, this is only for the low pressure return side, for the high pressure im getting one made although the stock 240sx hose would probably work.
Got the preliminary cutting and flanges welded on the xpipe. Got to go pick up my mufflers and the rest of the mandrel bends i need to finish this tommorow.
Here it is installed on the car.
As you can see there is no illusion of grond clearance here, my car is pretty low ( as low as the tein coilovers will go) and i have about 3 and some change inches of ground clearance. It should be fine as the other one hung about as low and only became an issue on some speed bumps and going on and off the trailer. Besides it aint any lower than the headers
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 09-19-2008, 06:59 PM   #152
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
removed as requested
g6civcx is offline   Reply With Quote
Old 09-19-2008, 09:21 PM   #153
Def
Originally Posted by g6civcx View Post
How is BSFC related to throttle position and minor fluctuations in speed?
There's a BSFC curve for every throttle position. RPM is related to speed. Unless that's a rhetorical question, in which case I've got nothing.
Old 09-20-2008, 07:15 AM   #154
g6civcx
g6civcx's Avatar
Old 09-20-2008, 10:15 AM   #155
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Ok guys, who gives a rat's fucking ass about fuel consumption here? The OP doesn't and neither do I!!! Take your bickering to PM so the rest of us can enjoy the build. And seriously g6civicx, arguing about fuel consumption when you have a carburated 350 chevy under the hood? Get real!
racepar1 is offline   Reply With Quote
Old 09-20-2008, 10:16 AM   #156
Antihero983
Antihero983's Avatar
^see! that whats I was saying!!!!!!!!!!!
Old 09-20-2008, 12:33 PM   #157
Def
What I mean is that you generally don't hold a steady cruising speed.
You generally slow down a little bit and speed up a little bit even when cruising.
So it's not practical to calculate the max point of the BSFC curve for a single speed.
So would a single max point on the BSFC or more like an RPM range, say 500RPM or 1000RPM range, that would make more sense to analyze for fuel consumption?
I never said anything about a max POINT of BSFC. It's a curve, there will be a minimum which will move around wrt RPM depending on other variables.
Changing speed slightly or not, the BSFC curves for say every 10% throttle opening will show you where an engine is most efficient.
Enough of the tangent, BSFC and how it relates to fuel economy isn't that complicated. I'm sure there's a wikipedia article on it or something.
Old 09-20-2008, 01:24 PM   #158
SicBastard
SicBastard's Avatar
I recently subscribed to motortrend, and every issue has more than one BS article about gas milage. Pisses me off. Who gives a shit. This isn't a thread about tuning. So why are we talking about BSFC?
Looks like we have some motortrend readers here in zilvia.
BURN OUT IN YOUR FACE!
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
Old 09-20-2008, 01:31 PM   #159
g6civcx
g6civcx's Avatar
I asked a question. I have no position so how can I bicker?
If you don't like the questions then I am sorry but I did not bring up the topic.
First, nowhere am I arguing. I am asking because I want to know.
Second, I have many cars, not just one. What makes you assume everything is about that one car? Any additional followup may be done on PM as this does not concern anyone else.
If you don't like what you see, please ask a mod to prune. I'm just responding to what others have said.
I am leaving this post as a rebuttal to accusations about me that may or may not be true. I do apologise for participating with others who brought up a tangential topic. Please go to the other thread if you want fuel economy.
Old 09-20-2008, 01:32 PM   #160
g6civcx
g6civcx's Avatar
I made a new thread and copied all relevant comments in there. Please feel free to have a mod prune this thread.
Old 09-20-2008, 02:03 PM   #161
Def
I feel sorry for you if your only introduction to internal combustion engine topics is Motortrend...
I never read that trash.
Old 09-20-2008, 02:20 PM   #162
SicBastard
SicBastard's Avatar
It was $10 bucks for the year.
I got ripped off.
Old 09-20-2008, 04:23 PM   #163
gsracer
Ground clearance is for sissies
Dual 3 inch exhaust, xpipe, dual magnaflow mufflers
ANTI-STRETCH NAZI
Old 09-20-2008, 04:35 PM   #164
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
looks fuckin awesome dude.
Review Thread
bardabe is offline   Reply With Quote
Old 09-20-2008, 05:18 PM   #165
turtle m3th
turtle m3th's Avatar
Trader Rating: (41)
turtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond reputeturtle m3th has a reputation beyond repute
Feedback Score: 41 reviews
That's some great work! can't wait to see some new vids of that thing in action!
"cigarettes killed my father, and raped my mother!"
turtle m3th is offline   Reply With Quote
Old 09-20-2008, 05:27 PM   #166
jspec240
jspec240's Avatar
jspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfection
Fuckin nice Exhaust set up man. what kind of wheels are you running? specs?? Great fittment.
Over all great job man A+
DREW
SLIDE TO SIDE WORLD WIDE
Feedback!! http://www.zilvia.net/f/showthread.php?t=182673
661 sliders Gymkhana @ buttonwillow
http://zilvia.net/f/south-western-st...-sessions.html
>> Bakersfield Hook up thread <<
jspec240 is offline   Reply With Quote
Old 09-20-2008, 05:58 PM   #167
s13 @ fullboost
Spirit Of Ecstasy
s13 @ fullboost's Avatar
this One is sooooo much better than the last one =]
Old 09-20-2008, 06:09 PM   #168
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
Wowzers that is clean as fuck
Rock on.
d-faction.com
Landers is offline   Reply With Quote
Old 09-20-2008, 06:38 PM   #169
gsracer
Thanks for the compliments everyone, i do think this time around the car is coming out better
front 18 by 10+18
265/35/18
Rear 18 by 11 +18
315/30/18
Finnally got the car on the ground its got plenty clearance, never again will i be able to take a speed bump though. The pictures look like the mufflers hang lower than the bumper , but its not really that much, they are tucked nicely under the car.
ANTI-STRETCH NAZI
Old 09-20-2008, 06:41 PM   #170
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
awesome work
I'm still not sure if I like the exhaust sitting that low.. call me a sissy but I'd prefer not to worry about scraping it on a speed bump.
still very cool and unique
keep it up
random question: I noticed you had some different tires on the car is that temporary or is their a story behind that?
JRas is offline   Reply With Quote
Old 09-20-2008, 06:45 PM   #171
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
this build makes me wet
clark is offline   Reply With Quote
Old 09-20-2008, 08:14 PM   #172
energy0uth
energy0uth is an unknown quantity at this point
very very nice....not on here enough but I should be for builds like this
energy0uth is offline   Reply With Quote
Old 09-21-2008, 12:16 AM   #173
TUnity2
TUnity2's Avatar
TUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of light
very nice. Do you plan on adding some tips?
Possibly twin slash cuts angeled up and out?
TUnity2 is offline   Reply With Quote
Old 09-21-2008, 12:30 AM   #174
Oo_Skyline_oO
Oo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud ofOo_Skyline_oO has much to be proud of
Send a message via AIM to Oo_Skyline_oO
fu*kin shwwweeet, get it to sound like this please: YouTube - 1UZ Toyota V8 with ITBs
oh and sorry to bring up the fuel economy thing again, but would it be possible to mount a T56 trani to it??? I beleive that would fix the problem, if a corvette can get 30mpg on a 5.7 this is a 4.5, should get upwards of 30????
http://video.google.com/videosearch?hl=en&safe=off&resnum=0&q=30%20mpg%20c orvette&um=1&ie=UTF-8&sa=N&tab=wv#q=corvette%20vs%20prius&hl=en&emb= 0
Oo_Skyline_oO is offline   Reply With Quote
Old 09-21-2008, 12:44 AM   #175
gsracer
yes, anything is possible but the extra 2 grand youd have to spend would negate 5 years worth of the difference between the two fuel economy wise.
ANTI-STRETCH NAZI
Old 09-21-2008, 12:56 AM   #176
xplicit240
xplicit240's Avatar
xplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nice
Send a message via AIM to xplicit240
amazing. simply amazing.
xplicit240 is offline   Reply With Quote
Old 09-21-2008, 01:45 AM   #177
jspec240
jspec240's Avatar
Nice sizes. what brand and model though?? there isnt a pic on here that shows what they are. to me the last side pic where you can see like a quarter of the wheel look like my favorite wheels of all time that I missed the bid on ebay but if you have them I think that would be cool and would deserve a home with you... haha
The deep g7's
DREW
Old 09-21-2008, 03:00 AM   #178
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
a lot of goodies you got there. nice. love the pics and keep them coming. thanks.
Modrified is offline   Reply With Quote
Old 09-21-2008, 07:38 AM   #179
gsracer
The deep g7's
They are work meister s1 3 peice
ANTI-STRETCH NAZI
Old 09-21-2008, 02:52 PM   #180
gsracer
got it cranked back up, sound is amazing the video doesnt do it justice. The smoke is the oil in the exhaust being burned up, at least i hope lol
YouTube - 450sx new dual 3 inch exhaust
ANTI-STRETCH NAZI
