03-15-2010, 05:02 PM | #1 |
TRUNK locked
k so suddenly one day my trunk is locked. i unlock my car but the trunk is locked.
the trunk open/close button near the gas tank button has always not been working. anyways was wondering how i can fix this without costing me huge amoutns of money |
03-15-2010, 05:49 PM | #2 |
s13/s14 ??
If it is a S14, drop the back seat, get about 2 feet of extensions and a 12mm socket and take the latch off the trunk lid. You'll then be able to get in and disconnect the wires to the latch and open it up to diagnose.. My bet is that the lever that you can push down to disable the trunk release in the cabin got pushed down. If not you have a similar problem that i have dealt with for quite some time and the latch/striker are disagreeing and you're gonna have a bitch of a time making it work again.
Rebuilding it one bolt at a time. Got any spare bolts? |
03-15-2010, 08:18 PM | #3 |
I've got a similar problem with my S14, Trunk unlocks, and the Trunk Release on the Gas Door lever works, but if I lock the car, go shopping, and come back and try to open just the trunk, it will not turn. It sucks
03-15-2010, 08:39 PM | #4 |
what model is it? s13 or s14? your latch is in need of some grease the next time you get it open. take it off and lube it up and you shouldnt have this problem anymore
03-16-2010, 07:58 AM | #5 |
S14, the latch is secured with M6 bolts, 10mm head, not 12mm.
There's a cancel switch on the latch that prevents the pull handle from opening, it's a valet feature. Make sure the switch is flipped up. You can also adjust the tension on the latch to ensure the lid pops up when released and doesn't sit on the latch, allowing it to lock when the cable is released.
03-17-2010, 03:07 AM | #7 |
i have the same problem with mine, i broke my key so now i cant open it and my latch doesnt work, its an s13 coupe, any help on getting mine open again and get the latch working too?? kinda thread jack sorry
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines |
