07-01-2012, 03:08 PM | #61 |
very very very cool, all the work thus far looks extremely professional. im in till the end, hope you meet your goal!
www.elevenspaint.com |
07-01-2012, 07:30 PM | #62 |
What brake setup are you running on the front? I really like those drilled rotors! Any more info would be greatly appreciated. The build looks great!
**The atypical S-chassis enthusiast*** |
07-02-2012, 01:54 PM | #63 |
Thanks,.
hope i meet my goal indeed. haha the front brakes on the picture are the r33 gtr drilled brembo discs 324mm. (r33 gtr setup) the brakes wil be replaced with ap 343mm front and ap 330mm rear when the car runs and is readdy for track time. regards.. |
07-02-2012, 03:20 PM | #64 |
found some pictures i didn't post.
it is a while ago.. some of the fpr, feul filter and oil relocator incl, thermostat. bulkhead feul supply feul line sockets under car. then my wallet was empty haha,... some safety on the passenger side. and a shot of the extra nismo's 9,5j x 18 and bbs e26's spot the cat haha!!! regards rik |
07-03-2012, 04:10 PM | #66 |
Awesome build!!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 |
07-03-2012, 09:24 PM | #67 |
Would you consider turnung the oil filter assembly upside down so you don't get oil a;; over everything when changing thre filter? Or do we think enough will run out the line into the pan?
07-22-2012, 07:34 AM | #68 |
indeed thats something to think about
little update for today mount the powersteering reservoir and the water overflow tank (thanks chase bays, service turned out verry good) bay and interieur in the epoxi primer some seam sealer undercoating seal in the engine bay because i want to make 1 perfect set of nismo's i had to disamble the set's nice overview for my kouki front i mounted the oilcooler this way. and because i change my mind on the exterieur i need to make it like this the whole change need me to do an other rear wing and a little sneek of the front end regards,. rik |
08-15-2012, 02:17 PM | #72 |
hi.
thanks.. little update had some problems fitting the gearbox in the tunnel so did some drawing some cutting some welding it took me 5 nights to make this as it is right now i'm pleased with the result even the centerconsul fits great. got bussy on the front end and pre preparing for the fpr bonnet to cut in half because it doesn't fit over the intake manifold. want to do some simulair thing like the e46 m3 bonnet next week i'm planning to get the car to my work and there i can do the electrics and the engine hardware.(fuel lines cooling etc) so update's could take a few weeks. thanks for the interest. regards rik |
10-14-2012, 12:09 PM | #75 |
littl update!
moderators can put my build in projects/build section if they want been bussy with the angliment arms all arms driftworks and cusco, and a set of geomasters note: i know the camberarms are the wrong way after: turning up the coilovers. can't wait to fit the nismo's now the electronics all new wire's and my own setup the wood will change its easy to make changes now soon more! |
10-15-2012, 10:16 PM | #76 |
Awesome build, happy to see you got back into building it up. Hope to see more vq's, I really think there's untapped potential in them for s chassis.
11-25-2012, 12:48 PM | #86 |
after all this wireing it runs.
so i can do some bodywork poly trunk bonnet chargespeed wide fenders rear final connexion wide front fenders navan bodykit rocket bunney rear trunk spoiler give the nismo's a polish some glue after the binnet clearance isue this came in on my work so this happend and fitted the nismo's with toyo r888 tires that it for now regards, |
