Old 05-18-2008, 11:43 AM   #1
CusCo_S14
CusCo_S14's Avatar
CusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud of
s14 need help w/ headlights
first off its a 95 s14se. i have glass headlights and hids.i want to know how do i keep my low beam(hids) on when i need to flip the high beams on. i know hids are already bright enough but want more. IVE SEARCHED.
CusCo_S14 is offline   Reply With Quote
Old 05-18-2008, 11:51 AM   #2
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
firat off you better have a HID retrofit in there. i had to have a buddy in a older S14 follow me around with HIDs and i cal tell you for a fact that it i s blinding in the rear view even with it flipped down twice. other than that you are going to need to get the wiring diagram and disable/ add in relays to make it function as you want. shouldn't be that hard.
Tenchuu is offline   Reply With Quote
