Z32 26mm Aluminum Caliper Set - Rebuilt
Selling a set of Z32 calipers that I rebuilt using a Z1 Motorsports rebuild kid. All seals changed out including the small seals between the halves. Had them sandblasted and painted a bronze/gold using VHT caliper paint. Stuff is supposed to hold up extremely well to heat.
Does not come with pads or the hardware (the pins or aluminum part that goes over the pads). I have the bleeder valves, caps, and bolts for the spindle.
CALIPERS ARE DISASSEMBLED IN PICTURES, WILL COME FULLY ASSEMBLED. I already changed out the seals and boots, just need to bolt the halves together. Will probably give it one more coat of paint after assembly.
******FRONTS SOLD*****
SELLING REARS FOR 120 SHIPPED
Reason: price drop
