Old 08-02-2007, 01:25 PM   #1
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Feedback Score: 163 reviews
****Broadfield's New Interior Mods****
Finally finished the Defi gauge setup in my 240. I decided to make my own cluster using Defi gauges and then 3 more in the center vent location. I used the green Defi Link gauges with the brand new V.S.D. Concept X heads up display. In the main cluster I used a 80mm tach and boost, along with 52mm EGT and water temp. I gutted the entire OEM cluster leaving only a small black trim section that would frame my gauge plate that houses the Defi's. I also gutted the rear white section of the cluster which clips to the front glass and the black trim left over. I used 1/4" hardboard as my new cluster plate. Flushed in the gauges and retro fitted the turn signals into the plate. I reused the green arrows for the signals and used 1" pvc for bulb housings.
Now for the cool part. Since Defi does not make a speedometer gauge, I decided to go with the HUD for the windshield. I was going to retrofit the Defi HUD module into the OEM HUD pod that I bought off of another member. Figured it would look nice and OEM. Come to find out they discontinued the V.S.D. Concept. So I bought the Concept X instead and molded the module into the top of my steering wheel shroud. It works and looks flawless! I won't go into detail but basically I bondo molded it in and used texture paint on both the top half and bottom half. Then painted it a nice SEM black. Here are a bunch of pics and one of the Concept X HUD the way it comes new.
EDIT: New interior pics on page 9
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 08-02-2007, 01:29 PM   #2
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
Who needs a speedo anyways?
Looks very good.
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 08-02-2007, 01:31 PM   #3
amplifi3d
amplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-known
i applaud you on your execution. Very clean and creative.
What about low fuel warning light and check engine? Those are the other two i would be worried about. i guess you could always add those later.
amplifi3d is offline   Reply With Quote
Old 08-02-2007, 01:31 PM   #4
A Spec Products
A Spec Products's Avatar
A Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfection
Send a message via AIM to A Spec Products
Wow
Impressive
I think you need a better looking steering wheel tho lol
A SPEC PRODUCTS CORP
AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more!
626.618.1100 x 103 / aim: aspectuan
Advertiser's Specials! Read / Give Feedback! Please Rate Us!
A Spec Products is offline   Reply With Quote
Old 08-02-2007, 01:37 PM   #5
BattleRoyale
BattleRoyale is an unknown quantity at this point
super clean
very nice work
BattleRoyale is offline   Reply With Quote
Old 08-02-2007, 01:40 PM   #6
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
wow... that's almost as nice as having a stack...
ok... maybe not... but that's one clean setup there...
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 08-02-2007, 01:40 PM   #7
TougeRacing
TougeRacing's Avatar
TougeRacing has a little shameless behavior in the past
that is a crazy cool set up.
TougeRacing is offline   Reply With Quote
Old 08-02-2007, 01:47 PM   #8
2iv0 sx
2iv0 sx's Avatar
2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute
Concept X looks amazing on the steering wheel shroud.. How'd you do that?
Did it come with the shell covers to mount the HUD?
2iv0 sx is offline   Reply With Quote
Old 08-02-2007, 02:19 PM   #9
holaback
holaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymoreholaback is not welcome here anymore
All that shit and a homo steerinng wheel? I guess your a bfe boy it's not unexpected.
holaback is offline   Reply With Quote
Old 08-02-2007, 02:20 PM   #10
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
Man with that dash, I hope the rest of your car doesn't look like poo.
+1
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ [email protected]@[email protected]!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 08-02-2007, 02:23 PM   #11
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
I like it alot.
Looks clean.
Now hit up Logan for a Nardi wheel and Works Bell hub and QR.
azndoc is offline   Reply With Quote
Old 08-02-2007, 02:24 PM   #12
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
I'm impressed... very inspiring...
Nikeboy355 is offline   Reply With Quote
Old 08-02-2007, 02:30 PM   #13
DOOK
DOOK's Avatar
DOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfectionDOOK is close to perfection
tits, very tits
<------ Grumpy Old Asshole
MY REVIEW THREAD: Ltdnismoracer4=DOOK
http://www.zilvia.net/f/showthread.p...ltdnismoracer4
DOOK is offline   Reply With Quote
Old 08-02-2007, 02:33 PM   #14
scottie
scottie's Avatar
Awesome!!! Simply beautiful to look at!
Old 08-02-2007, 02:34 PM   #15
projectRDM
projectRDM's Avatar
Check engine light = emissions related items. I seriously doubt he's got a smog legal KA with all the goods, so a check engine light is useless.
To the OP- very clean, nice job.
FORMERLY R240NA
Old 08-02-2007, 02:39 PM   #16
exitspeed
aWingThing.com
exitspeed's Avatar
Really, really nice job.
Old 08-02-2007, 02:47 PM   #17
KwKouki
KwKouki's Avatar
KwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfection
Send a message via AIM to KwKouki
I posted your pictures up in the interior thread, hope you dont mind. Yo you do comission work?
KwKouki is offline   Reply With Quote
Old 08-02-2007, 03:04 PM   #18
McRussellPants
McRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond repute
Thats pretty classy
McRussellPants is offline   Reply With Quote
Old 08-02-2007, 03:05 PM   #19
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
Fuck yeah!
Cool ass cluster
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 08-02-2007, 03:10 PM   #20
ms!3
ms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfection
Send a message via AIM to ms!3
fucking clean. nice work.
ms!3 is offline   Reply With Quote
Old 08-02-2007, 03:20 PM   #21
Farzam
Farzam's Avatar
Farzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfectionFarzam is close to perfection
Mmmmmmmmmmmmmmmmmmmmmmmm taaaasteees goooooooooooood
loading HATERS.....99% ███████████████]
Farzam is offline   Reply With Quote
Old 08-02-2007, 03:25 PM   #22
Taniguchi_Is_#1
Taniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfection
damn. i like. +1 for you.
Taniguchi_Is_#1 is offline   Reply With Quote
Old 08-02-2007, 03:28 PM   #23
WERDdabuilder
WERDdabuilder's Avatar
WERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfection
god that shit is sexy.
got more pictures of the HUD? is it moded into the steering cover thing?
When the power of love overcomes the love of power, the world will know peace
WERDdabuilder is offline   Reply With Quote
Old 08-02-2007, 03:51 PM   #24
C. Senor
C. Senor's Avatar
C. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfection
Send a message via AIM to C. Senor
it looks very nice....i want to lick it, it's just so clean.
Don't forget to tell your mom, she ran out of eggs this morning!
C. Senor is offline   Reply With Quote
Old 08-02-2007, 04:26 PM   #25
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
I like the multi display HUD unit, center cluster is very clean as well.
Good work!
I think the original poster likes having a steering wheel with an airbag?
CKAMC is offline   Reply With Quote
Old 08-02-2007, 04:58 PM   #26
Irukandji
Irukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfection
Send a message via AIM to Irukandji
WOW, very cool interior.
I love it.
Irukandji is offline   Reply With Quote
Old 08-02-2007, 05:04 PM   #27
eastcoastS14
eastcoastS14's Avatar
eastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfectioneastcoastS14 is close to perfection
Send a message via AIM to eastcoastS14
posi rep......and hey if you start buildin em id buy one, would you be willing to make another one somewhere down the line?
eastcoastS14 is offline   Reply With Quote
Old 08-02-2007, 05:26 PM   #28
FinalDrive
FinalDrive's Avatar
FinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud of
that looks awesome
great work, especially on the HUD setup
FinalDrive is offline   Reply With Quote
Old 08-02-2007, 05:33 PM   #29
Irukandji
What did you use to texturize the bezel?
Old 08-02-2007, 06:03 PM   #30
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
I was wondering the same thing.
Also I didn't see a fuel level gauge anywhere, how do you know how much fuel you've got left.. I take it this is a track only car (theres no odometer for one thing)
Anyway, Excellent work, you should be proud. I think all of us have considered this at one point or another, but you're one of the first I've seen pull it off so cleanly.
MELLO*SOS is offline   Reply With Quote
