Old 09-10-2014, 12:22 PM   #1
datm3
datm3 is an unknown quantity at this point
Pulleys
Is there a difference between s13 SR20DET pulleys and s14 SR20DET pulleys?
I'm looking for a set of Greddy Pulleys, but can't seem to find a solid answer on s13 vs s14?
Thanks guys!
datm3 is offline   Reply With Quote
Old 09-11-2014, 08:32 AM   #2
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
I believe they are different.
Kaifd3s is offline   Reply With Quote
Old 09-12-2014, 01:09 AM   #3
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
SR20DET pulleys are going to work on another SR20DET engine.
Rayne is offline   Reply With Quote
Old 09-12-2014, 01:25 AM   #4
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Yes there is a difference, its small but the S13 has one extra rib on the one of the pulleys(don't remember which pulley has the extra rib). S13 pulley set will physically fit on the s14 sr20 motors. If you are using S14 belts with the S13 pulleys on a s14 sr20 motor, one of the belts will be a tad too thin. You can make it work by swapping the crank pulley and using the correct belt or just ignore the small gap.
The note/disclaimer here just confirmed what I was saying.
http://www.frsport.com/Megan-Racing-...ed_p_1377.html
eek is offline   Reply With Quote
Old 09-12-2014, 01:36 AM   #5
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Ok here is the real answer since I figured it out the long way..the only difference between the two are the s13 sr20 have one extra rib for the power steering pulley..so the s13 crank will also have one extra rib on that section but the rest is the same.
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 09-12-2014, 09:06 AM   #6
Mikester
Mikester's Avatar
Mikester is a well-known jackass
My $.02- GReddy pulleys are the bees kness... but lightweight pulleys are lightweight pulleys. If you desire blue anodized, there are tons elsewhere & on Ebay for your application. Far cheaper, same exact functionality. Anyone familiar with my motor will tell you that I don't normally promote off-brand stuff- But this is one of those few cases where the economics aren't there. Circuit Sports, hell even *cringe* ISIS Megan are cheaper alternatives with at least a little bit of QC behind them.
I know you didn't ask that specific question, so I will close with telling you that if you've got the $$$ for GReddy pulleys, then just get the correct set for your motor. Hope this helps.
Mike
Mikester is offline   Reply With Quote
Old 12-10-2014, 02:43 PM   #7
datm3
BTW, because I utilize my motor in another car, I don't make use of the power steering pulley if that makes a difference. I only need the water pump and alternator pulley.
