Old 10-06-2010, 08:11 AM   #1681
SoSideways
SoSideways's Avatar
How would the inner heims be in bending? They rotate vertically on the inner bolt.
Every aftermarket front arm uses heims like that on the inner.
Driftworks geomaster hub knuckles V2 article:
Geometry nirvana | Driftworks
I hadn't had my coffee yet when I made that post yesterday.
I'm drinking some right now.
Originally Posted by DC Dan MAX USA View Post
Although the prototype parts are that way, and work just dandy...
The outer bearing on the FLCA is fully enclosed on the production version.
Roger that.
Good deal.
Old 10-06-2010, 05:45 PM   #1682
Z33dori
Z33dori's Avatar
god dammmit
Old 10-06-2010, 06:05 PM   #1683
95KA-Turbo
95KA-Turbo's Avatar
Their car isn't low at ALL, they're running 19s if I remember correctly:
I can't wait to get my crap all set up so I can take pictures of the suspension for the last freaking time and drive!
Instagram - SJKnoop
Old 10-06-2010, 06:37 PM   #1684
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
Can anybody explain why the sway bar on the driftworks car is mounted to the bottom of the RLCA and why it is mounted so low? Thanks!
Slidin' Sam is offline   Reply With Quote
Old 10-06-2010, 07:03 PM   #1685
Def
Stock the cars mount the sway bar down there. As far as why they were too lazy to make an angle bracket above the existing bracket and move the endlink up, you got me...
DEFSPORT
Old 10-06-2010, 07:05 PM   #1686
PoorMans180SX
PoorMans180SX's Avatar
Nah, 18's all around.
Because the sway bar is always mounted to the bottom of the LCA? Have you looked under your car lately?
Not as low as some of us, but not exactly high:
The knuckles still correct a lot of the drop. I wish they would give us a shot of the front on the ground.
Old 10-06-2010, 07:24 PM   #1687
S14DB
AFC #1
S14DB's Avatar
That's the stock location on S14/15.
Old 10-06-2010, 07:37 PM   #1688
Def
S13s too.
Only on Zilvia is a car that's tucking a bit of tire "not low at all." haha
DEFSPORT
Old 10-06-2010, 07:54 PM   #1689
Slidin' Sam
Wow! Sorry, I had just woken up and I recently had knee surgery so I have been under the influence of some heavy pain pills! Whoops! I guess it just looked funny to me...I couldn't stop looking at it! lol
Old 10-06-2010, 08:00 PM   #1690
S14DB
AFC #1
S14DB's Avatar
Can you elaborate on this more?
Old 10-06-2010, 08:20 PM   #1691
PoorMans180SX
Those are the universal Battle Version/Driftworks/Godspeed lower arms.
Old 10-07-2010, 02:02 AM   #1692
articdragon192
articdragon192's Avatar
here is view of the rear.
you can see that with our sway bar mounted so high it will keep the maximum ground clearance for the bottom of the link
a view with the car on the ground
Like this. Places the endlinks higher up for more sway bar clearance.
I wonder if these arms would work on a Z32.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 10-07-2010, 07:14 AM   #1693
SoSideways
SoSideways's Avatar
I don't see why not.
It's like the exact same as the S-chassis rear arms, with the exception that you'll need that steel insert for the upright.
Old 10-07-2010, 07:19 AM   #1694
Slidin' Sam
does anybody know just how much extra "traction" you can dial in with aftermarket traction rods? like can you make a significant improvement on grip with them? I'm going to pick a pair shortly, just curious as to what other people have noticed from having them.
Old 10-07-2010, 07:22 AM   #1695
SoSideways
SoSideways's Avatar
The length of the traction rods can help with keeping the toe change to a consistent level as it compresses and expands, almost eliminating the toe out situation as the rear suspension compresses.
Old 10-07-2010, 07:37 AM   #1696
Slidin' Sam
so I guess you can almost use it as a second toe rod then yeah? i just really need to add more grip to the rear of my car without buying more expensive tires.
Old 10-07-2010, 09:33 AM   #1697
slider2828
slider2828's Avatar
So at this point you extend the traction rod a little further than what stock is toi achieve that?
Turn and Burn!
Old 10-07-2010, 09:45 AM   #1698
Slidin' Sam
Yes.
From PSM web-site:
~Increase traction by shortening this rod 1cm from stock length on higher cars or lengthen this rod for super low cars for correct geometry.
Old 10-07-2010, 10:50 AM   #1699
PoorMans180SX
When they make the S13 version, you can simply bolt them on your Z32. S13 and Z32 lower arms are the same.
Old 10-07-2010, 12:32 PM   #1700
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
MAX RLCA sway bar position is exactly the same as the OEM RLCA.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 10-07-2010, 12:56 PM   #1701
GripTerror
GripTerror is an unknown quantity at this point
I AM HOPING that you guys develop the rear drop spindle with z32 shock mount... not only will you make me happy you'll attract z32 owners to this... and... if im not mistaken the later r chassis r34 uses z32 style rear spindle no? Plus j30? I think?
GripTerror is offline   Reply With Quote
Old 10-08-2010, 07:15 AM   #1702
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
On a double wishbone suspension, when you make an RC correction to the lower control arm, do you also have to make a correction to the upper A arm? Will it mess up you camber curve if you don't?
Pandapants is offline   Reply With Quote
Old 10-08-2010, 07:27 AM   #1703
SoSideways
SoSideways's Avatar
Yes.
From PSM web-site:
From the research that some of the NRR guys did, yes, you lengthen the rod when you have lower than stock ride height, and at one point, there was barely any change in toe, going from droop to compression.
Old 10-08-2010, 08:54 AM   #1704
Slidin' Sam
I'm sorry, but who are the NRR guys?
Old 10-08-2010, 09:00 AM   #1705
thefro526
thefro526's Avatar
Nissan Road Racing
thefro526 is offline   Reply With Quote
Old 10-08-2010, 09:03 AM   #1706
GripTerror
The kick ass real car guys Sorry just messing with zilvia
Old 10-08-2010, 09:30 AM   #1707
Slidin' Sam
Originally Posted by thefro526 View Post
Cool, thanks! Never heard of it before!
Haha, I just started reading through the site, looks pretty legit so far. Oh, and I don't see anything wrong with your comment!
Old 10-08-2010, 10:25 AM   #1708
onehundredoctane
onehundredoctane's Avatar
anyone know if these are aval off the shelf for the S chassis? just wondering if the taper of the ball joint on the outter tie rod is aval on an adjustable tie rod adapter like the one in the link below. . .
Adjustable Tie-Rod Adapter Stud to Heim
I've just started keeping up with this thread and one of the main things I want to fix on my s chassis is the tie rod angle. Any input is appreciated!
Old 10-08-2010, 11:13 AM   #1709
Slidin' Sam
looks like you just want an aftermarket tie-rod end.
Old 10-08-2010, 11:17 AM   #1710
slider2828
slider2828's Avatar
NRR is another website which Def, codyace, and a couple of others belong too. It stands for Nissan Road Racing....
SPL tie rods and most aftermarket tie rods include heim joints, just depends on the quality of joints you want.... So far SPL has been the best.... MR and Kazama suck loose after about a year....
Turn and Burn!
