Old 02-02-2010, 07:01 PM   #1
hamiltonbmx
hamiltonbmx's Avatar
hamiltonbmx is an unknown quantity at this point
Sr20 wont start
my SR will crank over but it wont start i checked and im not getting any spark in any of the wires. im not sure what it would be and i blew the 75a fuse in the fuse box by the intake manifold and got another but it was corroded but it still got power to the interior lights and didnt when it was broken.
hamiltonbmx is offline   Reply With Quote
Old 02-02-2010, 07:22 PM   #2
KoukiMonsta
KoukiMonsta's Avatar
c'mon trouble shoot it a little at least
1 figure out what the fuse is for
2 check grounds(back of head)
3 check ignitor
@UpshiftEngineering
Old 02-02-2010, 07:25 PM   #3
hamiltonbmx
how do you check the ignitor because thats what i think it is too i already checked grounds
Old 02-02-2010, 07:36 PM   #4
KoukiMonsta
swap with a friends is the simplesst
@UpshiftEngineering
Old 02-02-2010, 07:38 PM   #5
hamiltonbmx
theres only 2 240s that have things actully done here my friend but he has the 1jz swap and me with the Sr
Old 02-02-2010, 09:16 PM   #6
KoukiMonsta
google and search around for a ignitor test method(via multimeter)
@UpshiftEngineering
Old 02-02-2010, 11:43 PM   #7
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
Next time please search more.
Check your ignitor chip, make sure it's plugged in and wires are clean and pins have good connection. Also double check your ignitors as well.
It just sounds like drivers from the computer arent quite reaching your coilpacks to fire
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 02-03-2010, 09:17 AM   #8
rubhamusan
rubhamusan is an unknown quantity at this point
What ecu codes you getting? If voltage drops below 10.5 amps during cranking it will not fire.
rubhamusan is offline   Reply With Quote
Old 02-03-2010, 10:56 AM   #9
KoukiMonsta
hey steve, did you mean that? or should it be coil packs or somthing? please elaborate
@UpshiftEngineering
