Old 02-09-2014, 09:40 PM   #1
chipsahoy
chipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymorechipsahoy is not welcome here anymore
SR 93 Blacktop SR Swap problem HELP PLEASE
Dear fellow Zilvian's,
Okay so i just finished my S13 SR20det Blacktop with J4 ecu and wiring harness. I finished and turned the key and nothing. my fuel pump turns on and it cracks but not starting at all. I know that the j4 blacktop wiring harness as some different colored wires at the 2 plugs next to the battery and i'm not sure if i wired it correctly. Anybody that wired this up before with the OEM j4 harness and ecu can to please tell/show me how you did this please?
chipsahoy is offline   Reply With Quote
Old 02-12-2014, 01:50 PM   #2
frankies1390
frankies1390 is an unknown quantity at this point
what do u mean it cracks? turns over? i would check the grounds, then move to starter signal wire. sounds like u have ignition power but its not reaching to ur starter (if its not turning over) but if it is make sure u have power to ur ecu first.
frankies1390 is offline   Reply With Quote
Old 02-12-2014, 02:33 PM   #3
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Verify the CAS / timing is 100% perfect.
blkvrtswp is offline   Reply With Quote
Old 02-19-2014, 09:45 AM   #4
chipsahoy
Okay so I figured out why it wouldn't start. I didn't have my ignition coil wire wired in correctly (blue w/red stripe) so I wired it in with the main ignition wire (black w/red stripe) and it tried to start but no dice. So I replaced the old spark plugs with new ones and it started and runs great.
