Old 10-20-2011, 09:37 PM   #1
Sil#2
Sil#2 is an unknown quantity at this point
Sti injector adapters?
Trying to find some adapters for sti injectors cause I just hate wires. Searched and all the links are now dead. EBay doesn't state these specific adapters. Anyone know where I can still get these? Thanks.
Sil#2 is offline   Reply With Quote
Old 10-20-2011, 10:21 PM   #2
waxball88
waxball88 is an unknown quantity at this point
Buy STi injector plugs and replace stock plugs.... I believe the are denso "ovular" connectors. A lot of the subies use the same clips go down to u-pull and take clips off a car that matches.
waxball88 is offline   Reply With Quote
Old 10-20-2011, 10:31 PM   #3
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
I was wondering this same thing, because I didn't want to splice in the plugs I have just to change them for something that works with stock connectors later haha. Is there any adapter available that plugs into the oem harness and sti injectors?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 10-20-2011, 10:33 PM   #4
waxball88
I don't believe so.....Its 8 wires.....solder and shrink them
Cut them off and repeat for different injectors.
I believe my plugs were off a legacy but don't quote me.
Old 10-20-2011, 11:12 PM   #5
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
You may be able to depin the connector and move it to the STI injector connector for a cleaner conversion. I will trying this myself since I'm also using the yellow STI side feed injectors on the SR motor I'm working on. GL!
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 10-21-2011, 06:53 AM   #6
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
This doesnt work.
Only the Denso top feed pins and the subaru side feed pins interchange on the connectors.
lok is offline   Reply With Quote
Old 10-21-2011, 06:58 AM   #7
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
I just jammed sr20 clips onto them upside down
fullthrottle is offline   Reply With Quote
Old 10-21-2011, 07:37 AM   #8
waxball88
Originally Posted by lok View Post
This doesnt work.
The pins on my injecors are in there REALLY fucking tight.
Old 10-21-2011, 07:40 AM   #9
gretz
gretz's Avatar
gretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the rough
Shave the "tabs" off the side of the injectors (a dremel or W.H.Y) and the stock sr caps should slide right on...
gretz is offline   Reply With Quote
