Old 07-11-2010, 11:13 PM   #1
DeeJay1337
DeeJay1337's Avatar
DeeJay1337 is an unknown quantity at this point
S14 To G35 Brembo Conversion Question
So I picked up a set of Brembo's from a G35... So i'll do a nice write up on this but I still have a few questions.
Everything is bolt on from what I figured out. But here's my question...
S14 Stainless Steel lines would work right? or Z32 Conversion Brake lines?
Second... For the rear e Brake... If I got the Rear R32 Ebrake Conversion lines, would they work with the brembo's?
A TINT AND DEBADGE IS NOT A FUCKING MOD!
DeeJay1337 is offline   Reply With Quote
Old 07-16-2010, 06:54 PM   #2
DeeJay1337
DeeJay1337's Avatar
No one can help me on this?
Old 07-16-2010, 08:35 PM   #3
projectRDM
projectRDM's Avatar
Only the fronts bolt on, and only after you drill the spindle holes to 14mm.
Z32 lines must be used, with the IF fitting. A banjo fitting won't affix to the caliper.
FORMERLY R240NA
Old 07-16-2010, 08:41 PM   #4
iLagX
Trader Rating: (40)
iLagX is an unknown quantity at this point
Feedback Score: 40 reviews
Send a message via AIM to iLagX
WHAT HE SAID!!
MAKE SURE YOU HAVE THE 14mm BOLT THAT CAME WITH THE CALIPER AND CUT OF YOUR BRAKE DUST SHIELD>!
iLagX is offline   Reply With Quote
Old 07-20-2010, 10:12 PM   #5
DeeJay1337
DeeJay1337's Avatar
Ok, but I also have the rears that I wnt to use. Do I need different rotors? with teh R32 Ebrake cables?
Old 08-09-2010, 01:34 PM   #6
DeeJay1337
DeeJay1337's Avatar
Any help on this?
Old 08-14-2010, 02:32 AM   #7
DeeJay1337
DeeJay1337's Avatar
I still need some help on this, to see what I can do to make my Rear G35 Brembo's work. Im trying to see if it can get an STI Rotor will that work with my ebrake?
