Old 03-03-2017, 07:48 AM   #1
Ichiban4
Ichiban4's Avatar
Ichiban4 is an unknown quantity at this point
NISMO 2 Way LSD R200
SOLD
close thread
☆ Panda Pirates ☆
Ichiban4 is offline   Reply With Quote
Old 03-04-2017, 05:39 PM   #2
Ichiban4
Ichiban4's Avatar
Weekend bump
☆ Panda Pirates ☆
Old 03-10-2017, 12:59 AM   #3
Ichiban4
Ichiban4's Avatar
bump bump TTT
☆ Panda Pirates ☆
Old 03-10-2017, 11:34 AM   #4
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Do u have the input shafts?
Sent from my SM-G930T using Tapatalk
Luvs2slide is offline   Reply With Quote
Old 03-11-2017, 03:20 AM   #5
Ichiban4
Ichiban4's Avatar
Like it says above, no shafts ect, you'd have to use your own. Slightly negotiable on price.
☆ Panda Pirates ☆
Old 03-11-2017, 10:35 AM   #6
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
I thought all the Nismo diffs use special input shafts. Are u certain the stock shafts will work?
Old 03-11-2017, 06:55 PM   #7
Ichiban4
Ichiban4's Avatar
No, I don't know for sure, you would have to research that.
☆ Panda Pirates ☆
Old 03-11-2017, 09:14 PM   #8
Ichiban4
Ichiban4's Avatar
From my research r33 skyline, z33, q45, and possible g35/37 all could be possible shafts to use.
It is 31 spline
☆ Panda Pirates ☆
Old 03-11-2017, 09:51 PM   #9
Nismoboy1992
Nismoboy1992 is an unknown quantity at this point
You can't use the stock shafts. I found that out the hard way from when I bought a 2 way and someone said that my shafts would work. Installed the diff and everything, put the car in gear and heard the rear end grinding.
The Nismo 2 ways are 30 spline 31mm. s13, s14, j30 stock shafts are 29 spline 30mm. I had to source s15 6 bolt 3x2 shafts for it to be a direct fit for me since I am running 6 bolt 3x2 axles. Q45 should work too, but then you will have to have the right bolt pattern axles and may have to cut the shafts.
Nismoboy1992 is offline   Reply With Quote
Old 03-11-2017, 11:04 PM   #10
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
Not all, the earlier versions of the Nismo 2 Way LSDs stateside that were being sold in the early 2000s were direct drop-ins into open diff. pumpkins and stock shafts were also utilized. I currently have one on my car. You would have to know which version of the Nismo 2 Way which is being for sale here.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 03-12-2017, 06:01 AM   #11
Ichiban4
Ichiban4's Avatar
Thanks for the extra info
☆ Panda Pirates ☆
Old 03-16-2017, 08:42 PM   #12
Ichiban4
Ichiban4's Avatar
$399 shipped to your door takes it
☆ Panda Pirates ☆
2way, lsd, nismo, r200
