Old 11-14-2010, 06:31 PM   #1
fastbackinit
fastbackinit's Avatar
fastbackinit is an unknown quantity at this point
SR sr20 s14 wont exceede 70mph!!!!!
Well... I am working on a 95 s14 with a stock s14 blacktop sr swap with fmic and basic mods... mph speedo was def off so we switched to a oem kmh cluster now it "pegs" at like 195 kmh and jus bogs... the governor is kickin in how do I get rid of this problem? Any coments or suggestions are definatley appreciated... same prob on my s13 redtop swap... also ran insane up to 70mph until I installed boost gauge a/f ratio gauge and volt meter????? Now it bogs under WOT and even under normal load?????? Ugh...
Thanx so much...
In Christ,
Nick
89' s13 ka-e SINGLE SLAMMERS UNITE!
fastbackinit is offline   Reply With Quote
Old 11-14-2010, 06:34 PM   #2
tech_45
tech_45 is an unknown quantity at this point
Cut the wire from the speedo to the ecu. Then you can go infinity mph. I think its pin 42? and a green wire?
tech_45 is offline   Reply With Quote
Old 11-15-2010, 02:52 AM   #3
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Thanx so much...
In Christ,
Nick
You installed a boost gauge, check for a boost leak.
As for the governor search, it has been covered countless times.
LayNLow is offline   Reply With Quote
Old 11-15-2010, 05:18 AM   #4
fastbackinit
Oost leak test came back fine but thanx... I did a little search but didn't come up with anyting... thanx a lot!
Nick
