Old 06-09-2005, 04:41 AM   #1
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
S14 Nismo R-tune Coilovers
Just had a random curiosity on these. They look like a nice set, very typical coilover design.
Anyone have detailed specs on these? Searches on zilvia.net only yielded the S-tune non-height adjustable type. These are R-tune.
Courtesy Nissan link:
http://www.courtesyparts.com/Merchan...Category_Code=
they give no specs. how do they compare to a basic coilover set? from a random yahoo search, blu808 mentions they compare to Apex N1 but with the convenience of quick rebuild at a Nissan dealership.
nismo.co.jp does not help (they only have a parts catalog).
Any additional info on this coilover set would be great. thanks.
Edit: info and opinions will appear below as I continue research
Part Numbers for Different Nismo Suspension (i.e. S-Tune, R-tune)
240SX 1995-1998, 5300R-RS546-US
* recommended for track use only, fully adjustable
240SX 1989-1994, 5300S-RSS30-US
* performance street suspension
240SX 1995-1998, 5300S-RSS40-US
Best price so far:
http://www.thenissanpartsstore.com/P...sp?prodCatId=9
Specs
From Japanparts.com,
Height & Damping force(Front=4, Rear=8) adjustable
Adjustable Pillow Upper Mount is installed on the Front Strut
Front: Spring Rate=78.5mm(8.0kgf/mm), Adjustable Range ±20
Rear: Spring Rate=68.7mm(7.0kgf/mm)/9.8mm(1.0kgf/mm), Adjustable Range ±20
Owner Opinions
From Joey @Courtesy Nissan:
"Two guys here including myself run them. In my opinion they are smooth and a great value for the price. I ran JIC and Zeal B2s before them. The Nismo's responded the best on and off the track. Girlfriend still does not like the ride quality but you cant satisfy everyone. They dampen 4 way up front and 8 in the back. Kit utlilizes a small screwdriver(snap on brand) for front dampening adjustments, the rear has a huge knob on it...Hope this helps most of the information we have on these is in Japanese thats why our information is limited."
"They are not inverted. Spring rates are not printed any where that I can find. They have helper springs in the rear but not in the front."
Brian @ NICO who owns a set:
"There not harsh on the street at all, I mean they can be if you stiffen them out, I got mine setup for everyday driving, but there still very stiff, but dont take bumps bad at all. Example of how stiff these are, sometimes when I pull into driveways at an angle, the back wheel will lift off the ground, haha! But everyone that rides in my car compliments how nice it rides!"
(he needs a rebuild but comments that no dealership will help him)
"I havent been able to rebuild them though, noone will touvh them, and my nissan dealer, said nismo doesnt rebuild them, but i read somewhere they do, i dunno, im pretty fed up right ow, I need them rebuilt, well at least one of them! But other than that, they are awesome and id recomend them to anyone!"
TurDz is offline   Reply With Quote
Old 06-09-2005, 10:38 AM   #2
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
i was gonna ask the same thing. i was trying to find some info for a while. u can get at them at many dealerships too
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 06-09-2005, 01:08 PM   #3
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
8k front 7k rear. Fronts 4 way adjustable, rear are 8 way adjustable. I remember someone saying that they are built by KYB, but it was never confirmed.
atom is offline   Reply With Quote
Old 06-09-2005, 02:09 PM   #4
North240
North240's Avatar
North240 is an unknown quantity at this point
For the money i'd go with KTS, for $550 you get a new set of struts to replace blown ones = zero downtime/waittime.
ROUND 2
North240 is offline   Reply With Quote
Old 06-09-2005, 02:26 PM   #5
SHIFT_control
SHIFT_control's Avatar
SHIFT_control is a well-known jackass
if I was you, I would get the s- tune kit. Ive got them on my S13 and they work great, and your car won't be scraping the ground either. But then again, I'm just a parts guy at a nissan dealer........
SHIFT_control is offline   Reply With Quote
Old 06-09-2005, 03:46 PM   #6
TurDz
TurDz's Avatar
well, they look like KYB in the rear for sure. Just look at the knob design. Then again, it could be made by GAB.
Where did you get your 8k/7k information? thankks
Old 06-09-2005, 03:57 PM   #7
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
i see no point at all to get coilovers that arent height adjust. might as well go with spring/shock.
why spend that much money on coilovers and cant adjust the height. might as well spend the same amount o fmoney or a little bit more and get both height and dampering
SilviaDriver is offline   Reply With Quote
Old 06-09-2005, 04:06 PM   #8
SHIFT_control
thats what the s-tune kit is springs and shocks, much simpler install too
Old 06-09-2005, 04:15 PM   #9
OptionZero
OptionZero's Avatar
OptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfection
Send a message via AIM to OptionZero
he's not asking about the S-tune or spring/shock
Anyways, searching on FreshAlloy, people think the Nismos are built by GAB (which is KYB).
For roughly $1500, competition would be Silk Road Rm8, Buddy Club Race Spec, GP Sports GR6, and Tanabe Pro DD.
I believe Buddy Club and Tanabe are rebuildable in the U.S.
OptionZero is offline   Reply With Quote
Old 06-09-2005, 05:03 PM   #10
ZK
ZK's Avatar
ZK is making a name for him/her selfZK is making a name for him/her selfZK is making a name for him/her self
I don't how how you drive your car but rebuilding isn't a big deal for me. On my past car I had a set of Tein Type HA (6 years ago it was the best street set up available before Tein USA distribution and before the Flex, drift-spec stuff was available). I drove 50K miles of autocross, daily commuting and road course events on that suspension and they still worked the same when I sold them as when they were new.
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8
NEW: 08 Evoluton 10
ZK is offline   Reply With Quote
Old 06-09-2005, 05:11 PM   #11
420sx
420sx's Avatar
tanabe DO NOT have a rebuild facility. they will exchange however, under warranty and replace broken parts.
buddy club doesnt have a us facility. yet.
hydropgrahics!
ls1......
