Old 05-03-2005, 09:02 AM   #1
pacefarm
pacefarm's Avatar
pacefarm is an unknown quantity at this point
Send a message via AIM to pacefarm
*searched* 5speed swap - 5th gear, neutral, rotation sensors
what up everyone.
i'm about to start on my 5 speed swap this weekend. i printed out and read every faq and guide that i could find. seems pretty straightforward when it comes to the mechanical part of the swap. one thing thats not so clear to me, is all the sensors that are mentioned. speed sensor, rotation sensor, reverse light switch, neutral position switch, 5th gear sensor. do i have to buy all those, or is the car already equipped with those? probably a dumb question, but i am pretty worthless when i comes to wiring lol... anyway, any detailed help would be greatly appreciated!
pacefarm is offline   Reply With Quote
Old 05-03-2005, 12:09 PM   #2
SaGang227
SaGang227 is an unknown quantity at this point
They usually come with the manual transmisson unless the seller took them out.
Some plug right into the auto harness while others require some mild wiring.
SaGang227 is offline   Reply With Quote
Old 05-03-2005, 12:32 PM   #3
pacefarm
pacefarm's Avatar
damn.....guess i'll have to order those as well, since my tranny came stripped.. any diagrams or guides online that show where the sensors wire up to the harness? thanks for the response btw
Old 05-03-2005, 12:40 PM   #4
S14DB
AFC #1
S14DB's Avatar
The one by the shifter is the neutral position switch.
Under the tranny/shifter coming in at a 45 is the speed sensor.
The one in the center by the seam is the 5th gear.
one closer to the clutch fork is the reverse sensor.
the crank sensor is on top of the bellhousing.
Old 05-03-2005, 12:49 PM   #5
pacefarm
pacefarm's Avatar
where would those wire up to the harness? sorry if this is common sense, just trying to get as much figured out as possible, before i start wrenchin.
Old 05-03-2005, 12:57 PM   #6
S14DB
AFC #1
S14DB's Avatar
I take it you've never seen this: http://www.ka24development.com/cwilf...lectrical.html
Old 05-03-2005, 01:13 PM   #7
pacefarm
pacefarm's Avatar
awesome, just what i needed. really appreciate the help!!
