Old 08-26-2008, 02:15 PM   #1
zidek
zidek is making a name for him/her selfzidek is making a name for him/her selfzidek is making a name for him/her self
boost problems, already searched
fist off here are my few mods:
3in turbo back straight exhaust
koyo radiator
generic intake filter on oem arm
walbro 255 fuel pump
oem sidemount
it's pretty much a stock sr20det
over the weekend i installed a manual boost controller. i clicked it all the way down to 0 then guesstimated i'd try 8 clicks. then i took it out for a spin. at WOT through gears 1-3 i would spike to 10psi then it'll hold at 7 which i thought was perfect. then i went to my bro's place and let him take it out. i told him to really let on it so he opens it up. from a 1-2 shift he hammered there was a popping sound then a big woosh as if the intercooler piping came off (it's happened to me after first swapping). we check everything and it's all on tight. checked the oil and it was a little low so i put a quart in. i assumed the wastegate was still open cause thats the only other part that would let air out. but hoped the turbo wasn't blown since i only spiked to 10 (i watched the gauge the whole time). i then crawled home and it wouldn't go past 2psi and could barely go up hill at 10mph. it definitely felt like a n/a . since it was dark i couldn't really tell what kinda smoke was coming out but it seemed more white than blue. after some searching i had time to check it out today and found my brake fluid was really low from a loose cap and prolly my gas was a bit low but thats unlikely. i had to pump the gas to start it up today and the little smoke that did come out was white. i played around with the wastgate without taking it off and it still seems to work properly. all hoses are fine and oil levels are good. i still need to add brake fluid though. any idea on what it could be? thanks in advance
zidek is offline   Reply With Quote
Old 08-26-2008, 05:23 PM   #2
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Sounds like a vacuum leak is causing you to run pig rich. Check all your piping, and lines to be sure you don't have a leak somewhere. If you blew a coupler/pipe off it's probable that something else was knocked loose as well. Check vacuum going to your wastegate actuator. Trust me it could be anywhere, I had a hole in my intercooler I had to weld up after a wreck lol.
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
Old 08-27-2008, 04:29 PM   #3
drftthatshit
drftthatshit is on a distinguished road
might also be a head gasket are you burning coolant??????
drftthatshit is offline   Reply With Quote
Old 08-28-2008, 08:10 AM   #4
zidek
so i found the problem i overlooked it: this cap on my sidemount blasted off from the 10psi lol. thanks all for the suggestions. i think it's time for a front mount lol.
Old 08-28-2008, 05:15 PM   #5
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
or a new cap? that thing looks like old rubber.. we all kno what happens to old rubber...
t25 @10psi should not be busting stuff, and side mount is fine for the stock turbo
aNskY is offline   Reply With Quote
Old 08-28-2008, 05:19 PM   #6
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
those damn old rubber pieces...
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 09-02-2008, 04:58 PM   #7
zidek
as an update i replaced it with a white rubber cap that goes on the bottom of chairs (like the foldable ones) and walkers lol. found it at walmart for $2, it has a 1 1/4 diameter and JUST barely fit. it's really snug all the way on and i put the clamp for good measure. since i've upped the boost a little and everything is fine. thanks all =-]
Old 09-03-2008, 10:53 AM   #8
drftthatshit
walmart??????+nissans........weird but if the shoe fits!!! lol
Old 09-04-2008, 02:35 AM   #9
socal_kouki
socal_kouki's Avatar
socal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud ofsocal_kouki has much to be proud of
BTW blowing the wastegate hose wont kill your boost. You'll actually run full boost.
Ref: to first help post.
This used to be a cool forum.
socal_kouki is offline   Reply With Quote
Old 09-11-2008, 06:08 PM   #10
zidek
btw if anyone needed to know what it looked like
