Old 08-15-2008, 08:38 PM   #1
Nick 240
Nick 240 is an unknown quantity at this point
Can you tell me how to cap Power Steering?
I need to know how to cap the power steering cuz mine isn't working. I bleeded the system and used atf and it still doesn't work.i'm sure its the pump but i'm gonna drive the 240 w/o it. If you can please tell me how to cap the Power Steering.
Thanks
Nick 240 is offline   Reply With Quote
Old 08-15-2008, 08:42 PM   #2
S14DB
AFC #1
S14DB's Avatar
Take the belt off the PS pump.
Old 08-15-2008, 08:51 PM   #3
ms!3
ms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfectionms!3 is close to perfection
Send a message via AIM to ms!3
Ya, what about the water pump though?
ms!3 is offline   Reply With Quote
Old 08-15-2008, 09:15 PM   #4
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
Theyre not on the same belt
n240sxfnatic is offline   Reply With Quote
Old 08-15-2008, 10:04 PM   #5
ms!3
Oh damn, we talking about sr's here? Nvm then.
Old 08-15-2008, 10:34 PM   #6
supportTHEezln
supportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud of
Send a message via AIM to supportTHEezln
Mac-10 FTW.
You can cap anything.
And the word is "bled."
supportTHEezln is offline   Reply With Quote
Old 08-16-2008, 12:12 AM   #7
murda-c
murda-c's Avatar
ka power steering pump shares a belt with a water pump, no?
Old 08-16-2008, 01:38 AM   #8
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
Correct.
Kinda nice I guess, when my water pump seized n snapped the belt, I noticed I had no PS, and was able to pull over and shut off the engine before it overheated.
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 08-16-2008, 12:45 PM   #9
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
With the size of the steering linkage, your best bet is to score a spare rack from the junkyard, Open it up, remove the seals, pack it full of amsoil grease, weld the holes shut to prevent moisture.
Looping/breathing the steering rack still is fighting against the seals. Capping it is just fighting the seals and the fluid pressure.
I havent drained 90% of the fluid out of the rack and used it that way, too afraid of it drying out. However my Civic has maybe 10-20% fluid in the rack and is still running strong for 5 years now.
Bigsyke is offline   Reply With Quote
Old 08-16-2008, 08:36 PM   #10
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
IIRC, the PS and Water pump are on the same belt on teh KA24DE but that is not the case with the KA24E
Propaganda is offline   Reply With Quote
Old 08-18-2008, 01:43 PM   #11
Nick 240
i have a KA24DE is there an eaiser way to cap it cuz i'm planning on putting the power steering back on i just want it to be temporary.
Old 08-18-2008, 06:41 PM   #12
Bigsyke
Bigsyke's Avatar
There is no easy way.
Only real way is to remove the rack, remove the piston seal, adn lube it up with synthetic grease.
Old 08-18-2008, 11:01 PM   #13
Nick 240
ok thanks that is what i am going to do.
