Old 03-20-2013, 02:37 PM   #1
egk818
egk818's Avatar
egk818 is an unknown quantity at this point
s14 Radio Help
The other day while I was driving, I noticed the volume was really low and my volume button is broken so I couldn't increase or decrease the volume. A couple days later I noticed there was NO sound coming out at all. I'm not sure what it is.
Could the amp/fuses be done? Or is it just the fact that the stock headunit is bad? I also want to note that the radio powers on and off and can change stations so I don't believe it's a fuse but idk. Thanks in advance
egk818 is offline   Reply With Quote
Old 03-22-2013, 03:10 AM   #2
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Is it a base S14 or an SE model. If it's a base model, then the volume control on your radio is probably dead....time for a replacement. See if you can find someone here on Zilvia that is parting out a S14 stock radio. You can probably pick one up dirt cheap.
If your S14 is a SE model, pop the trunk & look underneath the deck lid where your back speakers are located. The two amps on the S14 SE model could have gone bad, hence no sound out of the radio. Same thing, check the For Sale section here on Zilvia & see if you can find someone parting out an S14 SE. You might be able to pick up the rear amps dirt cheap also.
Almost forgot, you might want to pop the door panels off the inside door portion & check to see if the PAPER cone on the speakers haven't gone bad. Check the back speakers too. If the paper cones on the speakers go bad, it could affect the sound out of your speakers / radio.
Anyhow, hope this helps....
Good luck!!
ID
PS:
Use the SEARCH function here on Zilvia and download a Factory Service Manual for your model year S14. It will help you troubleshoot problems with your radio & amps....
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 03-23-2013, 05:42 PM   #3
sr20det-s14
sr20det-s14's Avatar
sr20det-s14 is an unknown quantity at this point
What if your car is a base model with factory 6 speaker stuff like mine. Mine has the same problem
sr20det-s14 is offline   Reply With Quote
Old 03-23-2013, 09:43 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If you have 6 speakers, you have amps. I'm surprised there's still cars with the stock radios on...
CLICK HERE!!!
Old 03-24-2013, 07:58 AM   #5
sr20det-s14
Lol yeah I know my radio is part of the problem the other half is my amp wiring is all hacked up a and I can really do much about it cause my trunk won't open
